Traction control button dead? SOLVED
Ground_zero298
Scs michigan
I noticed my tc hero button seems to do nothing. Baja mode will disable the tc so I know it will turn off. Pushing or holding the tc button does nothing.
I did read someone else had this issue along with multiple parking brake failures and ended up being a parking brake module. I have had no such issues with the brakes.
Any ideas?
Cybindustries1904
Tony
Discovery bay
23 Raptor, Mach E GT
I have the same issue. Pushing the button for 7 seconds or for eternity does not matter it will not turn off. Does anyone have a fix so I don't have to take it to the dealership.
Ground_zero298
Ground_zero298
Scs michigan
I ordered a new switch bank. Will have it Monday.
Cybindustries1904
Tony
Discovery bay
Ground_zero298
Ground_zero298
Scs michigan
The dealer needs to update your comtrol module. Had the same issue.
I am still getting parking brake faults, but the TC turns off and on now.
Thanks for the info. I’ll check it out.
Ducati1098
Any ideas?
Ford Bronco Traction control button dead? SOLVED 21A85CAF-0967-40C5-82DD-AD683138DB95
Ground_zero298
Ground_zero298
Scs michigan
Paul Gagnon
Paul
Sherwood Park, Alberta, eh?
I'm curious why you ordered a new part when it is still under warranty. Did you modify it somehow?
Ground_zero298
Ground_zero298
Scs michigan
Like to fix my own stuff. Warranty or not. Blown engine would be a different story.
rtazz17
Connecticut
2022 Ford bronco big bend
rtaylor
R
ID
19Raptor, 22Bronco
