Traction control button dead? SOLVED
Ducati1098
Did a look through on the program. Didn’t see anything for how to clear it.
There should be something listed called “self test” Run that and then it’ll ask which modules, you should be able to select all modules
Ground_zero298
Ground_zero298
Scs michigan
Found it. All green now.
Typed self into the search bar. That brought it up. After the modules came up I hit test all. After that clear and reset put them back to green.
Thanks gain for the help. Only took 6 hours but now I got it.
rtaylor
R
ID
19Raptor, 22Bronco
Should all modules that are not green be updated? I only did the abs like you showed and it fixed my original problem. My ocd is curious though.
Sorry, I don't know if that is a good idea or not. After updating the ABS I ran forscan to check and clear the resulting DTCs caused by the ABS update
Ground_zero298
Ground_zero298
Scs michigan
I ran the self test and checked/cleared it. No issues.
Cybindustries1904
Tony
Discovery bay
23 Raptor, Mach E GT
Well here is a weird one. I had a dead TC button after the bronco updates last night magicly fixed itself.
