TPMS Adjustment
cjindna
DC
2022 Base Sasquatch 4 door 2.3l 10spd
For those of you looking to lower your tire pressures and update the TPMS settings to reflect your new base pressure the following changes may be made with ForScan (verified on my 2022 base).
BdyCM
Front: 726-10-01 - XXXX-XXXX-** (where ** is desired pressure converted to HEX)
Rear: 726-10-02 - **XX-XXXX-XX (where ** is desired pressure converted to HEX)
I have updated mine to a base pressure of 35 psi and now see a warning when pressures are reduced to about 30 psi
cjindna
cjindna
DC
Sasquatch has a default setting of "27" or 39 PSI front and rear
feralc
Fernando
Outerbanks
BdyCM
Curious why you opted for updating HEX values vs just making the change on the BdyCM configurable module itself?
Ford Bronco TPMS Adjustment 51A65810-9C69-4798-9731-711411ADA4B4
Ford Bronco TPMS Adjustment EF367BEC-4AB3-483A-8344-B4E392A73E0A
skierx728
Nate
MA
13 Wrangler Sahara Unlimited
Hi all, I'm not too familiar w/ TPMS systems... is there a specific type I need to buy when upgrading my wheels/tires that will be compatible w/ the Bronco? or are they all pretty much universal?
If anyone has any recommendations on reasonably priced options you've used that would be awesome. Thanks!
DogHauler
Chuck
2022 Badlands Sasquatch 4dr 2023 Black Diamond 2dr
Ford OEM parts, the counterfeit ones on ebay don't last.
d1977
Devin
Calgary
nothing anymore
i have a 2022 wildtrak/sasq, all tires are 35 pressure but right tire sensor orange still.
Even when the pressure is off by like 4, it creates an alert.
Wtf ? Faulty sensor for front right ?
Ford Bronco TPMS Adjustment A1E8B8FF-BC89-4F90-8B1B-AFCA0E6BAEBD
timhood
Tim
Several
Old thread, I know, but in case others are interested, I added a second set of wheels and tires to my Badlands and picked up these (https://www.amazon.com/dp/B06W9L93VY - 4 pack, https://www.amazon.com/dp/B08P2KN3VS - single pack) TPMS sensors on Amazon after doing a fair amount of searching to make sure I would get ones that worked, as it's $20+ to have tires dismounted just to replace a TPMS sensor. :(
Installer mounted the sensors and the tires and when I picked up the vehicle, they'd already connected to the Bronco and were reporting the pressure. Obviously I cannot report on long-term life, but these are highly rated on Amazon, which was part of my requirement in my search.
Raptor911
Raptor911
Broadlands, VA
I run these on my 22 Wildtrak. It is plug and play with no issues
4 >> https://www.amazon.com/dp/B06W9L93VY?psc=1&ref=ppx_yo2ov_dt_b_product_details
1 ( if you need 5)>> https://www.amazon.com/dp/B08P2KN3VS?psc=1&ref=ppx_yo2ov_dt_b_product_details
TeocaliMG
Plymouth Michigan
2021 Bronco Badlands non-sas 4 door manual
Hey, I disabled mine the same way in forscan. Disabled since I didnt have time to take my old wheelset to a shop before setting up and testing the new ones. I left it disabled for about 10 months and just did a teardown during my tire rotation to put TPMS back in and re-enable. After enabling, I got nothing... just a TPMS fault and no values for any tire. Install was easy, not sure what I could have messed up. Maybe I missed another step in forscan
Any thoughts?
BigHoof
PA
Ram 2500
Any thoughts?
Check the sensors to be sure they aren’t in deep sleep. Might need woke up.
TeocaliMG
Plymouth Michigan
How does one do that? Is there a way to "wake" them in forscan?
undoing my beadlocks (again) is very much unattractive at the moment
BigHoof
PA
Ram 2500
You need a TPMS tool. Who put the sensors in? If a tire place, they can check them for you. Most you hold next to the tire and it tells status including battery level. If asleep, it can send a signal to wake up.
May not be the issue but it shouldn’t be hard to check if you have access to a tool.
TeocaliMG
Plymouth Michigan
Well it would make sense I suppose since I had them of and stored away for 10 months... I put them on the new tires myself. Didnt think anything about it. They fit in my beadlocks just fine. Problem with the Beadlocks is I cant take them to any old shop, and I prefer to do it myself. But I just spent last weekend doing that... shucks
is that tool something I can buy online? wonder if it will work when mounted
Gtrekker
Gary
Yeah, your dealership has a module to reset them n their location. It's done in minutes.
TeocaliMG
Plymouth Michigan
Alright, i'll try that! thanks
