Towing 3,000+ lbs - Actual experience input requested
PAULWESTSKI
Paul
SE Virginia
00 F350 PSD, 05 Excursion PSD, VW-TDI
@23OBX2.7
There are not any lowering mods for that suspension type that I'm aware of. The camper rides extremely well on the independent coils, it is a relatively sought after suspension system. I don't want to loose ground clearance on the camper, we will be camping off the beaten path at times.
Air springs are inferior to replacing the coil overs themselves (band aids) They would also severely limit the suspension travel off road while not towing.
I have a heavy front winch bumper that required heavier springs so it made sense to replace the coil overs front and rear.
Ford Bronco Towing 3,000+ lbs - Actual experience input requested Independent Suspension
jakej
jakej
Jake
2016 F150
We are looking at some new travel trailers, and the ones we like best have a dry-weight ~3,200 lbs. So, with our stuff we will be close, if not slightly over, 3,500 lbs rating. I have towed our current, 2,900 lbs trailer for over 20k miles with the Bronco (2.7L V6). It tows great, with plenty of power and 17+ MPG, but I do feel the weight a little bit on downhills.
Request - I'm looking for input from other Bronco owners that have towed with trailers >3,000 lbs. Good/bad/other? Extra credit for those towing R-Pod trailers.
Note - I've read several other threads (and other sources), so understand how tow capacity works and to include passengers, luggage, etc. Really hoping to get actual experience vs. opinions. Thanks.
UPDATE - I thought I would circle back and let people know where our trailer search ended up, with help from this thread. This week we found and purchased a very little used 2018 RPod 179. This trailer has the perfect layout for my wife and I, including a bathroom and shower, which opens us up to wider travel options. We've been camping last 10+ years in a pop-up tent trailer.
The dry-weight of the RPod 179 is ~2,950, and I expect we'll travel between 3,300 and 3,500 lbs. The prior owner gave me his weight-distribution / sway bar hitch system (EAZ Lift 800), which makes a big difference in front-end stability (almost no bounce) on my test drives. We're heading out to Anza Borrego Desert next week for our trial run.
Ford Bronco Towing 3,000+ lbs - Actual experience input requested 1771087092269-30
FWIW - After reading posts to this thread, I did some research on weight-distrubtion hitch (WDH) vs after market shock options, and learned that the shock options don't really shift the weight off the vehicle rear-end. In other words, the WDH seems much more effective. This YouTube test was very helpful to me:
Thanks everyone for your help!
HoosierDaddy
__ Eric
NW. Indiana
3 pages deep now, not sure what all the other replies covered, but here is my testimony ... lol
I've posted this in a lot "towing" threads over the years.
I've towed the same load with numerous "trucks" ... The load being my Dad's Ranger fish-n-ski boat.
A year or three back I dropped the boat and trailer on the scales, loaded for a trip .... a hair over 3000 lbs.
Most recent tow vehicles:
  • 2006 Chevy 1/2 ton crew 4x4 , brand new motor, 5.3 V8.
  • 2021 Bronco 2dr 2.3 7spd 4.46 gears , using both factory 30" and aftermarket 35" tires.
  • 2023 Bronco Badlands 4dr (33") 2.3/ auto/ 4.46
Our normal trip has interstate, hilly 2 lane highways and back country county roads that are hilly and twisty. We have traveled the same route for literally decades. I know these roads well and how a vehicle handles them.
Of the three, the Badlands was the best puller. The 10 spd auto is straight up MAGIC. It made it feel like this set up had the most power. Yes, even more than the V8 truck.
Stability-wise, the truck with more length and girth weight was only slightly more stable. Very negligible difference.
I'd choose the Bronco every time. It does get pushed a bit in the twists and turns, but it was nothing that gave me any concern. The only vehicle I've had that made you forget the boat was there was a diesel F250 super duty ext. cab, and the Bronco or the Chevy ain't that. They both do fine, the truck is just a smidge more stable.
2nd place, I'd probably take the truck. Primarily because it has a "boat load" more room than the 2 door Bronco.
3rd in this contest of three is the 2dr Bronco. It really wasn't bad, the tranny being the weak link in the set up. It just felt like there were speeds that I didn't have the right gear. It made you remember that you're driving a 4 banger. So on steep hills, find that speed/gear that keeps it at 2700 rpm and let it purr away.
I don't recall having any issues in the twists and turns with the 2dr, it still handled really well, but what did stand out was the slight "whoops" that happen on interstate bridges. Between the boat pivoting and the short wheel base of the 2dr, it takes some getting used to.
It really gives meaning to the term "bucking Bronco".
The 2.3/auto did so well, it makes me wonder how well the 2.7 would do? I'd love to try !!!
Maybe give a 2.7 Ranger a whirl, see how that goes.
Ford Bronco Towing 3,000+ lbs - Actual experience input requested 1771090730965-d3
Ford Bronco Towing 3,000+ lbs - Actual experience input requested 1771090768890-3o
Ford Bronco Towing 3,000+ lbs - Actual experience input requested 1771090968801-z9
Ford Bronco Towing 3,000+ lbs - Actual experience input requested 1771091109814-m4
PAULWESTSKI
Paul
SE Virginia
Nice camper upgrade from a pop up.
You may want to research different weight spring bars.....something closer to the actual tongue weight.
The correct weight spring bars will allow the weight distribution system to be more compliant, and fine tuned to the towing configuration.
EAZ Lift (Camco) makes 400 and 600 WD hitches you may be able to use those bars in your WD hitch. Depending on what model you have.
Be cautious of severe angled approaches (parking lot entrances etc) folks have bent the camper tongue "A" frame with incorrect (too heavy) weight spring bars.
Safe travels on your maiden voyage.
SoCal
Temecula
Audi R8, Tesla Model 3 Performance, Bronco Sasquatch
great thread....looking to get a can am Maverick R Max which is about 2650 lbs...the trailer with braking system double axel is about 1200 lbs.
Will the 4 door 2.3 Sasquatch be able to handle this pretty easily?
Ford Bronco Towing 3,000+ lbs - Actual experience input requested Image 52
jakej
jakej
Jake
2016 F150
Sorry for the slow reply, we were out on another camping trip with the Bronco and RPod! 😊
If I understand your question, you're talking about 3,850 lbs with trailer and ATV? I assume that would be before any additional equipment, fuel, etc. If that is correct, my gut says that would be pushing the limit, perhaps too far. In the last few months we've made 3 long-distant trips (over 5,500 miles) towing the RPod, which I believe is ~3,200 lbs with our gear. I have a non-SAS, 2.7L, 10-speed automatic.
The Bronco does wonderfully uphill and flat-towing. But on long, downhill grades (>7%) it is white-knuckle time. The 3,200 pounds really pushes the Bronco downhill pretty good. On steeper hills, I need to keep it in 3rd gear and still apply the trailer brake every minute or so to keep under 45-50 mph. If steep and straight, no problem. But if steep and curvy (e.g., Tioga Pass out of Yosemite) it gets a little stressful. The Bronco power, and transmission are fine, it's just the extra weight pushing the 4,700 lb Bronco down the grade, as well as the softer suspension on the curves.
So, if it was me, I would not exceed the 3,500 lb rating unless I knew I was always going to be doing flat towing. If only flat, you might be ok. Note: If you decide to go for it, I would look into reinforcing the hitch system. I've had no issues after our three big trips, but do keep a close eye on the hitch receiver for bends and cracked welds since it is only rated for 3,500 lbs. Also, weight-distribution bars are a must for this much weight.
Tonka Bronka
Duncansville
F350, V60 Polestar, 900SS, K1300S, RnineT Racer
I noticed that you mentioned the soft suspension being a problem. There is no question that the rear suspension in stock form, is not up to the task of towing. I'm curious if you have done anything to address this? I picked up an off grid camper in TN (2600 lb. dry), and the first bump on the interstate bottomed it out. I went with the blue Sumo helper springs and that fixed it. I would even say that towing a 3500 lb. load without doing something to help the rear is dangerous.
jakej
jakej
Jake
2016 F150
I use the EAZ Lift Weight Distribution bars and they virtually eliminated any forward & back sway. But, I do feel a little bit of side-to-side sway in turns at speed (50+ mph) - nothing dangerous, but you do feel it and are reminded of the soft suspension. I'm not a suspension expert, but seems like stiffer springs would help.
Tonka Bronka
Duncansville
The problem with stiffer springs is that they are stiffer all of the time. The Sumo springs only come into play when towing if installed correctly, with an approximate gap of 1/2" between the Sumo and the frame. When towing, the frame will settle down on the Sumo and not allow bottoming while providing a smooth ride. Pulling an off grid camper with a fully articulating hitch will not allow the use of a weight distribution setup. The only time I have ever experienced sway is when my cargo tray, plugged into the receiver of the camper, was loaded with firewood and the tray was too far rearward. I moved it in 4" closer to the camper and the sway was gone.
Crunk
1988 Eddie Bauer 5.0
Brake controller, weight distribution hitch, and blue Sumo Springs in the rear and my 2021 Badlands 7MT had no issues pulling our 3500lb 2020 GeoPro 19GBH through the hills of northeastern Pennsylvania. We travel with a full water tank and gear for the whole family.
The 2.3 likes to rev, doesn't complain under load, and the temps never get high. Stopping is uneventful when the brake controller is set properly.
We did outgrow this trailer and will be towing the bigger camper with the Expedition this year but the Bronco happily pulls 3500 lbs.
ve been pulling a 3,300lb R-Pod with my 2.7L Bronco for about a year now and honestly it handles it fine, just make sure you get a good weight distribution hitch because the rear end will squat without it
The weight distribution hitches weigh like 50+ pounds and if tongue weight is already at 330 or so, that blows past the 350. It almost seems less safe to have one?
jakej
jakej
Jake
2016 F150
As mentioned above, the WD bars and hitch has added a lot of stability and control for me. I did a pretty long test-drive both ways and the Bronco was much more stable with the WD bars and hitch. This is despite the additional weight, which I was originally concerned about as well. This Youtube video helped me understand the physics much better.
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
I towed a rental Coleman Lantern 17 once with a WDH. I feel like the Bronco is under rated for towing, I barely knew it was back there and it had to be up around the 3500lb limit*. A few things to remember about towing:
Legal (I'm not a lawyer, but my understanding): Basically nobody is going to bother you unless there is a wreck with serious injury or death. If that happens, they might check weights, and if the trailer's GVWR is higher than the tow vehicle rating, you're screwed. Likewise, if the tongue weight and cargo of the tow vehicle exceeds the tow vehicle's payload, you're screwed. AND - I forget the exact configuration, but I think some 4 door Broncos, maybe with the v6, sasquatch, or both, have a lower tow rating of ~3200 lbs. Just FYI.
And I know someone said they used a Curt wireless brake controller and it was fine, but I used one and I thought it sucked. locked up the tires going downhill, a pain to use the app, etc. And now they require you to create a login just to use it!
ducksface
Stroppe
Grand Canyon, Arizona
2025 stroppe
Stroppe
I'm not a fan of ai.
But if you can counter what it's saying, please post an actual case.
I am not advocating.
I am debunking.
Ford Bronco Towing 3,000+ lbs - Actual experience input requested Screenshot_20260825_124308_Chrom
cbrenthus
Western PA
I am debunking.
maybe you're correc
I am debunking.
I appreciate debunking, and while I'm not a fan of AI we'll put that aside for now and I'll just admit that you have a good point. After your post, I tried but couldn't find any first person or news article about a legal issue for a non commercial vehicle towing over capacity.
but I did find plenty of hearsay, so I'm surprised your AI response is what it is.
and the bottom line these days, with civil lawyers, is that if you don't have anything to lose, you're probably good towing what you want, but if you have retirement savings, kids college funds, equity in your house, etc, and get in an accident overweight and an ambulance chasing attorney funds out, then you might be SOL!
Ford Bronco Towing 3,000+ lbs - Actual experience input requested IMG_9689
AZ4x4Adventure
Jason
Phoenix
64 Impala, 22 Explorer, 23 Big Bend SAS 2.7
I think that insurance covering your accident to replace your Bronco is much different than an injured party suing you for damages. If you have a solo accident with just your family involved, insurance does cover stupid (relative in Geico told me the same thing).
Would also assume that the cause of the accident would be key. If someone T-bones your Bronco, or rear-ends your trailer while towing, would be hard to put any fault on the tow capacity. If you rear end someone.....and they are seriously injured, then insurance is going to start looking at the tow rating and while they may cover your vehicle damages, i could see them go to court to avoid paying for the other driver.
However, stupid doesn't absolve you from civil litigation from another party.
On topic, I have been looking for a trailer that just touches the max 3500/350 rating for GVWR but it is very hard to find. They are either much lighter (smaller) or have a high tongue rate for the trailer weight.
