- First Name
- Jack
- Joined
- Aug 18, 2020
- Threads
- 2
- Messages
- 424
- Reaction score
- 932
- Location
- Temple, NH
- Vehicle(s)
- 2013 VW Jetta TDI, 2016 F350 4WD Crew Cab
- Your Bronco Model
- Heritage
The wiring needed for the brake controller to hook into the system is in the factory package.Depending on state, some require brakes at as little as 2500#, mine the threshold is 3000# and with a rated capacity of 3500 to avail of that full capacity requires trailer brakes. You can use the impulse systems built into the trailer (rent a Uhaul and you will see) or add a controller to your vehicle. In Alaska trailer brakes are not required until 5000#
In any event a brake controller is not included in the factory tow pack, just the hitch and wiring for lights
