Top speed in 4L?
Broncobreath
Patrick
Hamburg ny
2022 bronco
What is the top speed you can drive in for 4L?
HoosierDaddy
__ Eric
Wouldn't surprise me if it's only 45mph at redline.
Consult a gearing chart for a theoretical guess.
HoosierDaddy
__ Eric
I used a Ford's 10R80 trans, because that is what is available in the drop down menu . I'm not even sure what auto is in the Bronco, but I think the gearing is similar in all of these similar trannys.
So, on 35's with 4.70 gears @5500 rpm in 10th gear (.64 : 1) and low transfer.
2.72 t-case = 68.74mph
3.06 t-case = 61.11 mph
http://www.grimmjeeper.com/gears.html
SS Bronco
Shayne
Loomis CA
2021 Bronco , F600, F5, LJ20
Thanks for doing the math for us. But The broncos won’t shift pass 7th in 4 low. About 30 is top speed
HoosierDaddy
__ Eric
Cool, didn't know that!
7th gear comes out to 44 and 39 mph using the other inputs as listed above ... not that they are 100% correct, but should be pretty close.
Curiosity more than anything, I'd guess.
But I can see the use for "higher" speed lo range runs.
At the dunes, we had one classic Bronco that was freaking unstoppable in LOW, but we were spinning the hell out of it. There was not a dune out there we couldn't climb! Bang through the gears until it was in top gear and let it spin at 6k until you hit the top.
It just didn't do as well in Hi. We tried, but it just didn't work.
The other Bronco ran best in hi range. Plus the owner didn't like to spin it up like we did the 302.
Both were on 33's , one was a mild 302, the other was a pretty hot 289. Gearing unknown.
Broncobreath
Broncobreath
Patrick
Hamburg ny
2022 bronco
Again why
Do you want to worse gas mileage?
Man you’re very insistent on your why. Because I’m in Buffalo and we have 4 feet of snow. So I was gonna use four-wheel-drive low and I wasn’t sure how much how Fast I can go. Does that explain everything? Are you OK with that?
LockedBronco
Frank
PA
1972 Bronco
I wouldn't recommend doing it.
dgorsett
colorado
F250, Mustang, Explorer
Just a side note. Generally in low traction situations you're better off in high range unless you need more power.
