Top speed in 4L?
0ne
Nate
CO
Flex
In an old 1st gen 5 speed Ford Explorer I had to use 4lo on a very slick and steep major roadway because using the brakes meant immediate sliding and when the worst was past I couldn’t safely stop to switch out so I probably got it up to about 50mph in overdrive and while the engine was tached out and I could feel the drivetrain’s disappointment nothing exploded or was worse for the wear.
rtazz17
Rob
Connecticut
2022 Ford bronco big bend
If you are thinking about top speed in 4L then you shouldn't be in 4L. Unless you want to start breaking stuff.
LockedBronco
Frank
PA
1972 Bronco
Constant high RPM, engine oil temp, turbo temp.
If something let loose when you are doing 30 down the road in 4L I think dealer would put it under abuse.
rtazz17
Rob
Connecticut
Man you’re very insistent on your why. Because I’m in Buffalo and we have 4 feet of snow. So I was gonna use four-wheel-drive low and I wasn’t sure how much how Fast I can go. Does that explain everything? Are you OK with that?
Wow…………….
rtazz17
Rob
Connecticut
Yup……. Blow it up…. Its not mine.
dgorsett
colorado
F250, Mustang, Explorer
L
Same reason you can do a burn out in first but not second. Gear reduction multiplies torque, torque twists things twisting drive train spins tires, spinning tires don't go in snow. Slippery mode shifts to a higher gear earlier to minimize wheel spin.
Oldhippie
Barry
Santa Cruz, Calif.
Let me just say...what a bunch of nannies...these thing are so electrically limited it is nearly impossible to over rev/speed them...sometimes ya do actually need extra power to the wheels...sand and mud spring immediately to mind.
Broncobreath
Broncobreath
Patrick
Hamburg ny
2022 bronco
Look, I asked a simple question because of the amount of snow that we’ve had over the past couple days. I’m not looking to go to 50 miles an hour, but I wasn’t sure I could even go over 30 miles an hour. I’m not looking abuse the vehicle ,I don’t plan on staying in 4L. I didn’t realize this would become a controversy over me abusing the vehicle or trying to get crappy gas mileage. Thank you all over you that it contributed with a reasonable answer. Let’s end this now
Tricky Dick
Dick
PNW
www.TD-Distributing.com
AlpineDescent
Allen
Michigan, USA
Escape, Mustang
What I'm hearing is the manual is faster than the auto. 😁
That’s what I’m hearing too - now we’ve got to go try it tomorrow, TD, and see if we can beat 39!
AlpineDescent
Allen
Michigan, USA
Escape, Mustang
I thought it was a good question, just ignore the trolls.
HoosierDaddy
__ Eric
NW. Indiana
Let’s end this now
You're in the wrong forum for that. This is the land of armchair off road Kings of the Hammers.
Whatever it is you plan to do , you are either wrong for doing it or doing it wrong anyways.
HoosierDaddy
__ Eric
NW. Indiana
Just a side note. Generally in low traction situations you're better off in high range unless you need more power.
Hmmm, one of my "go to's" when I'm getting excessive wheel spin is shift into low and it seems to usually help.
The explanation I had heard was something to the effect of it slowing the delivery of the torque, albeit there will be much more available.
I'm not saying it's correct, I really don't know the particulars. I know what has worked for me in the past though.
