Top questions
mrc758
knoxville
F350
Have a 4 door hard top and I want to take the top off for a few weeks. Can I run with just the front and mid panels on without the rear roof panel? It seems like it would work but I want to ask those with experience. I may just get a bimini also but doesn't help for rainy days.
JohnnyBronco
Pennsylania
X4
The front panel attaches to the mid panel. Only on the non existent painted modular top can you run front and rear panels with mid removed AND have everything attached securely.
mrc758
knoxville
F350
Thanks. I was talking about just the rear removed and the front and mid on.
Lowcountry Bronco
William
South Carolina Lowcountry
Huh?
VIRUS
D
Wisconsin
Truck, car, feet
Not designed to lock in that way
Saw someone driving with the rear clam shell removed/ front two sections on. Looked kinda ridiculous.
The back of the mid section will be free to bounce around
Could get away with it if you limited your driving to low speed on smooth roads but what fun is that? 😆
Saltwater Junkie
Sir Fishin
Tar Bay,Va.
99 7.3 F350, 22 7.3 F350,25 2.7 BADLANDS SAS
Don't know why I visualized this,..
but hey it's yours,
Ford Bronco Top questions OIP
do as you please.
AKBronc49
Russ
Anchorage, Alaska
A lot of people doing it, 80mph on the Highway apparently without issue.
golfermurray16
Nathan
Charleston
Infinity QX80
Not sure about front and mid on and the rear off. But definitely confident in just having the the front on and all the others off. They all attach with that hook you have to mash down. No way a gust is undoing that thing. Im actually doing it tomorrow because I’m to lazy to put my bimini on.
AKBronc49
Russ
Anchorage, Alaska
Whatever you think Bud, here's multiple responses about it.
Ford Bronco Top questions Screenshot_20230508_113555_Facebook
Ford Bronco Top questions Screenshot_20230508_113611_Facebook
Ford Bronco Top questions Screenshot_20230508_113623_Facebook
Ford Bronco Top questions Screenshot_20230508_113630_Facebook
  • Like
Reactions: GAN
BlueBronco
DFW
Ford Bronco Top questions hard-time-anchorman
From your "multiple" responses:
1. One guy confirming panels can be installed quickly to prevent water intrusion but no mention of driving that way
2. Two guys stating they have done so with no comment on drivability
3. And another guy doing so but stating drawbacks at highway speeds
Is a far cry from:
OP, if you decide to do so, I would not recommend highway speeds unless you fabricate a bracket to secure the rear edge of the mid panel. Can you do so without it, probably, is it a good idea, probably not. Anything else is just terrible advice.
Also, note that Ford washed their hands of all responsibility, so should something bad happen you are on your own:
Ford Bronco Top questions 1683575860284
AKBronc49
Russ
Anchorage, Alaska
Is a far cry from:
oh Jesus christ dude. I've seen a hundred posts of people running them like this on the highway, do some research on your own. I pulled up the first post I could find. Do whatever the hell you want. You're worse than the towing weight crybabys on every forum when people post their setup.
BlueBronco
DFW
Ford Bronco Top questions giphy
Shane78
Shane
St. Louis
2D
Not what you asked…but I’ve done it on my two door on the Highway without issue with rear off, fronts on. For whatever that is worth. Good luck!
