Tons of noise in cold weather
Machinepirate
Bronco, BMW X5
Its really cold in Michigan right now and I am amazed at the whistling coming I think from the heating system and maybe the hard top. But also the creaking going on it sounds like a worn out car I drove in the late 70s. Must be the temperature range of all these plastics. Anyone else experiencing this.
Ibuprofen3293
Tom
Detroit
22MY Badlands
That whistle is driving me insane. Gets worse with vehicle speed and air speed. I removed the glove box and the passenger footwell duct to try to find it. I think it’s a leaking blend door—right behind the HVAC controls.
Machinepirate
Machinepirate
Bronco, BMW X5
we should take back to the dealer.
tourproto
Portland, OR
2004 BMW e46
I don't have increased wind noise in cold weather, but the hardtop creaks worse than my senior-aged knees when going over road irregularities and speed bumps. I thought it was the cold causing the roof panels to "contract" a bit and that these "gaps" were causing the creaks, but I took off the roof panels and re-seated them, but I still have creaks. It isn't a constant rattle, it is definitely a panel creak when I encounter bumps in the road.
harpo
not as many as I thought
I notice a difference in wind noise from the top as the temperature changes. The colder it is the more noise I get.
My HVAC on high is always load.
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
My 2023 2Door has increased whistling above the windshield in cold weather. Defiantly related to internal pressure or the HVAC as the bong rip bird whistle sound increases when the heat is on above 40 MPH.
indio22
Chicagoland, USA
My hardtop had been making some creaking noise in the cold. That noise and other stuff that bother some people doesn't bother me much though. I bought the Bronco because it's basically a new version of my 70's Land Rover and it's got the essentials.
Zero Options
Connecticut
When it got cold I had creaking coming from the rear of my 2 door that was driving me nuts. Somewhere on here it was recommended to lubricate the rubber seals around the tailgate and rear window. I tried it and the creaking completely went away. Maybe something to consider. I used Nextzett Gummi Pflege Stift (German I think?) rubber care stick that I got on Amazon.
LCW
Twin Cities, MN
2023 Bronco 2dr Badlands
Been single digits and below zero here in MN. I get the bird chirping sound as well. Noticed it starts roughly when temps get to about 10F. Gets worse as it gets colder. It’s right above the visor. Drives me nuts!!!
Haelous
US
2016 Mustang GT, 2023 Bronco Wildtrak
I agree that the heat whistle issue sounds like the blend door, because it only occurs when air is directed to the lower vents / leg area.
Also, anytime it is set to lower only (even manually) it also seems to shoot air out the defrost vents.
RimrockPaul
Paul
Rimrock AZ
2021 Ford F250
No problem in Arizona. Coldest I've had is 16.
jrollo7
James
NY
Range Rover Sport
Yes, it’s cold in the winter here too.
EVH1994
Yep, been having this issue in cold weather since I got it. Annoying AF and there doesn't seem to be a fix yet. The whistle on mine sounds like it's coming from the passenger window. I figured it was due to the cheap, flimsy windows.
williamshafer
William Shafer
New Palestine, Indiana
Jeep Rubicon
Getting wind noise and a little creaking from my hardtop. Don't notice anything from HVAC system though. Had two Wranglers and similar experience at these temps (near or below zero). These tops are removable and if you have moved them, then this isn't uncommon. I'm not surprised by it and it's not an issue for me. Off-road suv with removable top-this is par for the course.
