Tire stability on narrow tires
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
this is the tire chart published by discount tire for air pressure when changing tire sizes.
it accounts for load range type, original tire pressure, etc
it provides a good starting point
Zen89
Zen89
San Francisco
Ford Bronco
Did a chalk test on the tires. Dropped the psi to 34. Didn’t chalk completely even yet but it did feel a little better on a short freeway test ride up to 70mph.
Still waiting on getting that alignment. Also debating if I should’ve went 285/75/17 for a slightly wider tire too.
But thanks for the help everyone. Appreciate it! Few more pics just because.
Ford Bronco Tire stability on narrow tires 75325F5C-314C-4E51-87A6-EF1DA2614B6A
Ford Bronco Tire stability on narrow tires 719D80D9-89F7-435F-AAD0-73F83A1D287D
Ford Bronco Tire stability on narrow tires ABC7F5D4-6C75-421C-88A9-2B5C40F52E15
kodiakisland
Arkansas
Probably should have gone wider on 9 inch wheels. It’s just an odd mix to go wide on wheel and narrow on tire. That tire probably rides best on 7.5-8 inch rims.
Zen89
Zen89
San Francisco
Ford Bronco
I run 285/75R17 C rated Toyo OCAT3 at 36 psi on a 17x8.5 Method wheel with +35mm offset. Mine drives just like stock with the 285/70 BFG’s. I haven’t added the leveling kit yet, but my next stop will be the alignment shop.
I’m pleased with the tires, but they do have a slight hum at 70 mph. I’m hoping that goes away as they break in.
can you share a couple photos of your set up please. Thanks!
Lcubed
l
UsA
using the numbers from the discount tire chart (and a bit of matlab),
going from the standard black diamond tire size of LT265/70R17/C /Load Index of 112 (39 psi) yields an OE load of ~2075. (seems like a pretty high load for each tire)
for the TOYO 34"x10.5" Toyo AT3 D Load Index 120, the closest match falls between 35 and 36 psi.
LockedBronco
Frank
PA
1972 Bronco
Pizza cutters
old goat
Raul
Collin Co. Texas
Chevy Colorado
Thank you for those pics , that made up my mind not to get the 10.5 .
ill go with the 285/75/17
( I was leaning heavily on the kenda 35/10.5/17 )
orion
Jeremy
17' F-250, 17' Explorer
Here's an example of the Kenda's in 35x10.5R17...
Ford Bronco Tire stability on narrow tires 20220627_162748
Ford Bronco Tire stability on narrow tires 20220612_122209
Ford Bronco Tire stability on narrow tires 20220612_103300
Ford Bronco Tire stability on narrow tires 20220604_171644
Ford Bronco Tire stability on narrow tires 20220425_152127
Zen89
Zen89
San Francisco
Ford Bronco
Is the badlands slightly higher than a base/black Diamond? I think I might try your size. Americas tire is going to let me do a swap out.
Zen89
Zen89
San Francisco
Ford Bronco
Those Kenda’s look pretty good. I couldn’t find any weight specs on their website tho.
BroncoAZ
Mitch
Badlands is ~.4” taller than the other trims. The 285/75R17 will fit any trim from what others have posted.
The Kenda’s are on the heavy side, 66.62# per tire according to the rep at Kenda who responded to my inquiry. The Toyo’s in 285/75R17 are still heavy at 59# each compared to the 51# BFG’s that came on mine.
Zen89
Zen89
San Francisco
Ford Bronco
Thanks for your reply, I'm not worried about it not fitting. I'm running slim crash bars already. Your wheel gap just looked larger than what I currently have on my bronco so I was curious. Could've been an optical illusion, but thanks for the info!
