Tire Size / Recalibration Input Wanted
Heart2
Dan
St. Louis, MO
2022 Bronco Big Bend
I want to replace the 255s on my BB (when it gets here) with 275s. Is there a minimum size difference that requires recalibration? The 255R75/17s are practically the same diameter as the 275R70/17s (1/10 of an inch bigger). At 65mph, the difference is only .2 mph faster. I have never swapped tires on previous vehicles, so I really don't know what the standard is (if there is one).
Coloradonatives
Don
Fort Collins, Colorado
'69 Chevelle 2020 Chevy Traverse 2009 9-7x Aero
That is a minuscule difference- I certainly would not pay for a recalibration. It can be done if, and when, the time comes for other changes need to be made.
babraunagel
Golden, Colorado
Toyota FJ Cruiser
Yep, that's a pretty small difference. You can make the change yourself using the free FORscan software if you want.
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
I agree, not worth reprogramming for a less than 1% change. That is probably within the +/- accuracy of the speedo to accurately measure speed.
A 5% change might be worth it
A 10% change, yes I would use Forscan and make the update
Steve62
Connecticut
2017 Jeep Grand Cherokee
The attached link will give you an idea of how tire changes affect calibrations. It's pretty interesting. For example I have a BB too and am thinking about adding Sasquatch rims with 35" tires. According to the speed calibration window on this link, if I didn't recalibrate and my speedometer still thought I was using 32" tires, when it registered 60mph, i'd actually be going 64mph. The odometer would be off too.
https://tiresize.com/calculator/
