Tire question
Austino
Audi
Well my daughter has had her 25 OBX Sasquatch for just a few months and came home with some crazy wire coming out of 2 places on side of tire near bottom. Probably won’t plug tire because it is to close to the side? Is the tire a Goodyear wrangler territory rt? That is what I was finding online even though the tire on the truck does not say Wrangler just Goodyear twice on the tire where Wrangler stamp would normally go. I also didn’t see the tire in too many places online? Found one local for about $300? Thx for help!
Ford Bronco Tire question IMG_5253
Ford Bronco Tire question IMG_5252
Austino
Audi
Another pic
Ford Bronco Tire question IMG_5254
It is leaking.
Yeah it’s done then. cant plug the side wall - too much flex.
(I know this isnt the side wall but it is on the side biters or whatever they are called, which flex a lot too)
CalvinT
Calvin
Phoenix, AZ
See if Goodyear will cover it under road hazard. The Ford Warranty says tires are covered by the tire manufacturers.
Your dealer may be able to help if they're also a Goodyear dealer.
JawnyBronco
DelMarPa
2023 Bronco 4dr
… Is the tire a Goodyear wrangler territory rt? That is what I was finding online even though the tire on the truck does not say Wrangler just Goodyear twice on the tire where Wrangler stamp would normally go…
Yes, it is a GY Wrangler Territory RT. GY supplies the tire without the Wrangler badge for Bronco production at Ford’s request.
$300 installed is a fair price…
jjack50
Jack
Temple, NH
2013 VW Jetta TDI, 2016 F350 4WD Crew Cab
The tires are available from Tire Rack as alternate tread pattern. The best way to find them is to put in the vehicle info on the Tire Rack website and search for OEM tires.
DALOLA
Retired
Ohio 🇺🇸
'24 Mach-E, '22 Maverick, Hot Rods
That's a pretty crazy situation....any idea what happened? 😱
Agree with others, too close to the sidewall to plug/patch, unfortunately.
I'd consider just using the spare off the T/G, and throw some slime in this one, and mount it as the spare you'll likely never use....
Austino
Audi
I was already thinking about just switching out the spare. I’m not too familiar with my daughter’s bronco and was wondering how easy it is for the spare to come off the bronco? Doesn’t some brake light or some wires have to be disconnected or something?Guess any tire store could do it?
DALOLA
Retired
Ohio 🇺🇸
Nope, just remove the lug nuts, and pull it off.....but it's heavy, 85-90 lbs, so be ready!
Austino
Audi
Tire rack shows the Goodyear only on tire and not wrangler as other tire shops do? Not sure if this is accurate.
Ford Bronco Tire question IMG_5260
