Tire Circumference data collection
NewBroncoOwner
NewBroncoOwner
Good Ol USA!!!
2021 Ford Bronco Base
I think the best way to do this is:
- Drive on the highway at three different speeds like 55, 65, and 75 and use a GPS to see what actual speed is (for purposes of example here, lets say it is 61, 71, and 82)
- Calculate the ratio of those three readings (in this case: 1.109, 1.0923, and 1.0933)
- Take the average of those three ratios (in this case: 1.0982)
- Whatever value is in the as-built FORscan, multiply it by the average of the ratios (1.0982)
That should give you a really close result
as for the math and measurements;
285 /70 R17
32.7 inches x 3.14 = 102.68
102.68 inches x 25.4 = 2608.072 mm
With that circumference I get -3mph on the dash compared to GPS at speeds of 25, 35, 45. At 65, 70 and 75 I see a -5 mph on the dash compared to a GPS.
I have lowered it to 2525mm and will post what the numbers I get later today.
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
285 /70 R17
What was the as-built number from the factory?
NewBroncoOwner
NewBroncoOwner
Good Ol USA!!!
**UPDATE**
285/70R17 BFG KO2s Load C @38psi
With the tire circumference loaded at 2525mm, reduced from 2608mm, the speed on the dash read 30mph, GPS read 29.97mph. I may jump into FORSCAN and load the 2508mm to see if that -17mm from 2525mm makes a difference.
NewBroncoOwner
NewBroncoOwner
Good Ol USA!!!
*CONFIRMED*
LT285/70R17 needs a wheel circumference of 2508mm entered into FORSCAN to be 1 for 1 accurate to GPS speed.
Please add your circumference in mm's if running a 35", 37" or even 40" tire. This will help others dial in the speedometer when changing tire sizes.
jenkinslonewolf
Brockville Ontario
2021 Ford Bronco Outer Banks 2.3
I’m running 315/70 R17 SAS tires. Goodyear Territory. Tire size calculator says they are 2741mm but I entered 2600mm in Forscan and it’s bang on
Chawkbone
Medford, NJ
2022 Bronco OBX
I found that to be the case as well! Running Toyo Open Country III’s 315/70 R17
kirnma
Matt
Fairfax, VA
GMC Canyon
Yeah, this is exactly what I've been doing. I installed OBX take-offs on my Base and there is roughly a 5% difference in the the speed as measured by my GPS and my Bronco. I've ordered a compatible ODB device and will download FORscan and start by increasing the tire circumference by 5%, and go from there.
JohnnyBronco
Pennsylania
X4
This should help make it easier:
https://tiresize.com/calculator/
Diameter and ROLLING circumference (not to be confused with measuring tore with a tape) can/will/do differ between tire manufacturer for exact same listed size and tire type. A 10 ply tire of same size of a 4 ply will have a larger rolling circumference (maybe not much but measurable) than the 4 due to less sidewall flex.
Better source to compare diameters and rolling circumference for particular tires is www.tirerack.com
RHeinz
Ric
Houston, TX
The tire “effective” diameter also changes with the rotational speed. Watch a Top Fuel Drag Car doing a burnout. The tire geometry changes significantly.
Fly
MA
Subaru Outback
This is a great way to describe it. Thanks for helping me get a better understanding.
