Max tire circumference 2750mm
Yeti-X
Todd
Eau Claire WI
2022 Bronco Badlands 4dr
So I finally got around to playing with my forscan and the largest tire circumference that it would take is 2750. Is there a way around this?
Yeti-X
Yeti-X
Todd
Eau Claire WI
anyone
Jdc
Jon
Massachusetts
Bronco Badlands
That's .03 football fields
  • Haha
Reactions: abe
Yeti-X
Yeti-X
Todd
Eau Claire WI
You are correct sir or just slightly over
Yeti-X
Yeti-X
Todd
Eau Claire WI
but i need closer to .032 football fields
Ducati1098
I was able to go up to 2880, brought it back down to 2800 for my 37’s 🤷‍♂️
The calculations don’t make sense, because at 2800 that should be a 35” tire diameter, but it syncs up perfect with every GPS I’ve tried
Yeti-X
Yeti-X
Todd
Eau Claire WI
I tried 2899, 2850, 2800 on down even 2791 and nothing and yes 37's
Ducati1098
Are you clearing any codes and resetting/relearning vehicle data after you change the number?
Yeti-X
Yeti-X
Todd
Eau Claire WI
yep did a pcm relearn and initialize as well awd relearn and initialize one of the codes I had was the fact that the circumference was too large and the other code it got bad information becasue the circumference was too large
