Tinting question
Internationalraptor
1979 Scout 2
Going to have my front windows tinted to match the rear windows. I went to my local window tint expert and when I told him I wanted my windows tinted he winced. I’m like what’s up and he said it’s a pain in the ass because the door windows go down slightly when opening.
Does anyone know how these windows are getting tinted. I’m concerned with the process.
thanks.
Mlarv
TN
Most modern cars and trucks windows drop a bit when the door is open. I would find a different shop. I had mine done with out any issues.
615_Bronco
Cheatham, TN
2022 Bronco 2D BL, SAS, MT, & 2015 F-350 DRW
Frameless like a convertible car, so they go down when the door is open.
No idea how they do it but they say its a pain.
Sandbergo
Jelani & Dave
Orlando
Rogue
thanks.
Your local tint guy must be garbage. They are fairly easy windows to tint, I work at a shop and it’s probably one of the easiest we can do.
Sandbergo
Jelani & Dave
Orlando
Rogue
You have to trick the door trigger into believing the door is closed by putting the latch mechanism in the correct position then the window stays in the up position as if the door is closed. Clean the window and prep it for the film, spray slip solution on the film and glass and position the film, then squeegee the film. Trim the edges if necessary then clean it up and call it a day.
Eroc88
Ohio
Jeep
I would go somewhere else. I had my front windows done and it was ready for pickup in 1hr.
Alfa
Diego
Austin, TX
Bronco Wildtrak
I just had mine front windows done last week. The installer says that these are the easiest windows to do. Literally too the guy 5 minutes per side.
Langwilliams
Langley
Cleveland Ohio
2023 Bronco big bend, 2014 Harley Street Glide
I had mine done an the guy never said a word.
Gtrekker
Gary
thanks.
You need to go to a different / better shop.
He's sn idiot with no experience.!
Internationalraptor
1979 Scout 2
He never said he couldn’t do it. He’s got like 25 years experience. He’s done all my vehicles and they’re perfect. Not going with ceramic going to just match the rear tint.
what about the windshield? Isn’t there an extremely light tint that works well? Thought I’ve read that.
Batman
Guy
2022 Ford Bronco
thanks.
I went to my local shop, the same shop that I've used for all of my cars, and had mine tinted without an issue. Maybe you should look elsewhere.
A585
Nebraska
06 F-150, 2018 Elantra, 1980 Bronco
I was concerned with this also. Installer said no worries. A lot of new cars are like that now. I’ve had no issues and it’s been on there for almost a year.
Dubsesd
Andrew
CT
04 Ford F-150, 06 Roush Mustang
Easy. I do them all the time takes about 10 minutes.
