Thoughts on removing Braptor Frame support for Flip Down Attic Shelf
cyrus104
Braptor
I'm looking more organized ways of storing more gear for overlanding and came across the Mountains2Metal equipment. I've now have several other things from them and really like the gear.
So my big question is wanting to get people thoughts on removing the large cross member support in the back of the Braptor to enable something like the M2M Attic Shelf. Most of my time this is my Daily Driver and when we do go off road is fire trails / weeks long overlanding. We try to avoid doing anything that has a high likely hood of breaking our rig (obviously anything can happen). Our top speed overlanding on rough terrain is going to be like 30-50mph on washboards but small and medium rocks are crawl speeds.
https://mountains2metal.com/flip-down-attic-shelf-factory-speaker-compatible/
I know the brace is there for frame rigidity and adding stiffness but I don't think I'm pushing the vehicle to the range where that level of support is required... but I don't actually know.
Thoughts?
Ninjak
Miami
Hard call. The regular Broncosd does not have it, but they are no Raptors. You would still have the B brace, so.....
swamp2
It would be fine without it. You don't see non Raptors pushed hard off road without the brace having related issues.
That said, why not have your cake and sat it too by getting the American Adventure Labs cargo shelf which is fully Raptor compatible? I have one, but am waiting on all sorts of minor issues requiring cargo area trim removal before installing it.
cyrus104
Braptor
I do like AAL stuff and looking at them as well. I have the STP and looking at the MASS but really like the attic which is really high and tucked up in the hard top.
cyrus104
Braptor
Also comparing the AAL fridge pullout drawer to the M2M drawer that is the whole back. I like that it's the whole back that pulls out.
Mountains2Metal
Nick
Eastern, NC
2012 F-150, 67 Bronco, 94 Range Rover
He is referring to our attic shelf for having to remove the cross brace. Our cargo shelf is Raptor compatible.
https://mountains2metal.com/rear-cargo-tray-4d-bronco-6g-2021/
RIDE
James
Wasatch
‘23 Braptor, ‘71 Highboy F250, ‘54 Willys
Thoughts?
Theres other threads here about that brace and its importance. Some takeaways are it’s there (and not on regular broncos) to prevent body torsional flex both from Braptor having wider stance/axles and also being heavier than other trims. Also there for safety aspects.
I personally make sure mine’s in place to avoid the chance of future body squeaks from rumbling over rough roads at speed. I find once those gremlins show up you never get rid of em.
tourproto
Portland, OR
2004 BMW 330i, 2022 Bronco BL 4DR
The flip down attic is next on my "to buy" list. I think it is the best one around. Largest space and easy access when tipped down.
I don't have any squeaks in my 4 door BL. and I go offroad for hunting/fishing. Lots of bumpy, rutted county roads and no noise that really bothers me. I would say remove the cross bar and install it!
vrtical
Doug AI
GSMNP, TN
Fords
It's there for high speed stability. If your not blasting out west good to go with out it.
cyrus104
Braptor
Yeah, no blasting and currently no squeaks. I'll use the term brace in my searches to see if I find more threads on it, couldn't really find much with cross member support etc...
Spyder625
NJ
Caddy V, INEOS Grenadier
i heard if removed warranty is gone as well... so if anything happens you may not be covered.. check with ford..
c-dubb
Calvin
Braptor, Palisade
This. My Braptor has the squeaks and it's so annoying.
swamp2
My suspicion is the opposite. It's there for "bulk" flex that is more typical in low speed, crawling/flexing type driving. I.e. it targets body stiffness and the low frequency modes.
RIDE
James
Wasatch
I agree. At least for me, I’m finding it’s the asymmetrical hits at intermediate speed (~30mph or slower) where I'm either braking hard on rough before a hard turn or miss seeing a double-up rut when I hit hard to one side and feel it’s testing lateral torque. I’ve not visibly verified I’ve bottomed out but sure feels like there was nothing left in the shock when it hit. Running over cattleguards and culvert pipes asymmetrically at 50+ doesn’t even phase it.
