Third brake light relocation and install
MoeRighteous
New York
2023 Ford Bronco Wildtrak
Installed the “auto buero” third brake light from Amazon and was actually pleasantly surprised with its “plug and play“ easiness. relocated the third brake light, and did away with the factory light over the rear wheel. It really cleans up the appearance of the back of the car.
Excess wires were wrapped in in black zip ties in the wheel, and the connector [and spare connector] were wrapped with the tape included from factory and additional black electrical tape. I secured the looped wires with an additional zip tie to an opening beneath wheel bracket and it’s perfectly concealed by the tire. Not a bad update for 70 bucks. I didn’t want to start splicing wires and tinkering with the electrical system on a brand new car.
Make sure that the light you’re ordering is the newer version for the bronco and has a 3.1” opening in the center or you’ll be running into some installation issues. Very good quality product so far…
Ford Bronco Third brake light relocation and install IMG_1713
Ford Bronco Third brake light relocation and install IMG_1709
Ford Bronco Third brake light relocation and install IMG_1710
Ford Bronco Third brake light relocation and install IMG_1712
Ford Bronco Third brake light relocation and install IMG_1719
Ford Bronco Third brake light relocation and install IMG_1717
Darrell
Darrell
Maryland
2021 Ford Bronco Badlands Sasquatch
Excellent, it gives it a much cleaner look. I did the same thing but used Oracle's third brake light.
MoeRighteous
MoeRighteous
New York
Thanks! I saw the oracle and it looked nice.. Was the oracle “plug and play” or did you have to make some changes in the wiring?
Tricky Mike
21 Bronco
I have what looks like the same one, sold under the Offroad Gamers brand. It's nice not having to worry about tire fitment and you can carry stuff on the tire without blocking the light.
MoeRighteous
MoeRighteous
New York
I believe it’s the same as well.. another item on Amazon sold under 20 different crazy names 😂👀
