The issue no one is talking about. Or is it?
okbob
North of the Red
71' u15, 66' u14, 66' u14
If it’s a diesel you really should drive more than that,the fuel systems are so finicky and it’s 10k to replace it all.
Yes diesel and deleted. I'll go the other route and say the less fuel used the less chance for contaminates. We have rural fire trucks with 6.7l scattered all over the county that sit for over a month at time sometimes more. DEF issues are the only common issues we encounter.
ReimundKrohn
Reimund
Three Hills Alberta
2016 Rav-4, 2005 F-150 Lariat, 2005 PT GT Conv
I do wonder if they going to hire up to run 3 shifts around the clock once the Process is moving.
Yeah. At the same $17 an hour with little to no training for the inexperienced new recruits.. Good luck. 👍
s_white21
2021 F-150
I’m not worried about any of that.
Ford made this announcement because they know the new tooling works and they have a plan and schedule.
If they fall behind on the lot Broncos their whole timeline goes out the window and they’re screwed for the FEs
I think will see the June blends start to be shipped by mid October
Yes of course anything could go wrong especially these days but hopefully Ford will do it right this time.
Exactly this. I think they're likely giving themselves a buffer this time with hopes some will start shipping at the end of September and they'll be through the bad batch by the end of October. If they're not then they need to give up..
Bronc-O
Phoenix
2021 Lincoln Aviator
You guys do remember that 40 MICs/day were Webasto’s previous numbers? And that the DESIGN hasn’t changed, and that the SUPPLIER hasn’t changed, and that it is only a thicker application of the material + an edge sealing process that is going to be used? And that the new tooling required to accomplish this isn’t even in the Webasto plant yet?
….And you believe that Ford and Webasto are going to be able to crank out the higher quality MICs at a rate that is 10x faster than the original?
Man, there is optimism, then there’s this. 👆
Is 40 per day total yield or what was passable?
MN_OuterBanks
AW
Minnesota
2015 F150 SuperCrew
Utahbronco51
Leon
South Carolina
Toyota
Could not disagree more. New vehicles are a depreciating asset. They get less valuable every day. Ford needs to ship the vehicles now and ship the tops when available. Let's see them do the right thing instead of the easy thing. If they had tested the tops to begin with they wouldn't have this problem. Now we are paying the price.
WhiteMamba
Derek
Boring, Oregon
2021 Bronco FE, 2015 F350 2010 Focus 1995 F250
Old def for sure will mess with the emissions crap, I run supplement every tank for the crap diesel in my 6.7
Monster1926
Indiana
GMC Sierra 2500HD
Seems like if Ford were to allow soft tops on Broncos already built would ease some of the pressure. Someone mentioned that once the Monroney is created, the vehicle has to be built exactly that way, so that may not be possible. The time frame I keep seeing for new MIC is to START in October. Seems it would take some time to complete the over 2k waiting. How will they execute the process? Will a team go out to dirt mountain and simply swap? Will they bring them to a facility and wash them first and then swap the tops and perhaps do a QC on each one because they've been sitting a while? How many tops will Webasto be able to produce in a week? They will certainly be split between manufacturing and rework.
They won’t wash them, they pay the dealer to do that. They also won’t change them outside they’ll bring them inside. One person can have the top off in 15 mins. A lot of people are underestimating what Ford is willing to do to get these to the customer.
JaxGtc
There is no way they will clear that lot in a couple weeks. That basically means having all replacement tops in hand at MAP. And these tops will need to be removed and new ones put on by hand. At least an hours worth of work for each Bronco.
It will likely take longer to drive them over to a refit station than do the swap. Four or five people on each vehicle, the driver probably never even gets out, 5 minutes. Multiple stations, it goes as fast as the tops are available. Remember there are no roof racks, etc to work around for the most part.
BlueBronco
DFW
My understanding WAS, they will not build any MIC Broncos until the Dirt Mountatin Gang is shuffled through. Only soft tops ....and maybe FE's as soon as the tops are available, I'm a little unclear on that
That's what I thought as well, however, I was moved to 8/30 2 week ago and only moved once. That was the round of scheduling that saw people moved twice in the same weekend. Guess I will find out in a couple more weeks if I get built and exiled or postponed again. Not sure which is better or worse.
AZ_Liberty
2007 Expedition
OP has a point. When a new model year is available, the last year model on a dealer's lot can be purchased at a discount.
Only true to a point. Ford had zero incentives on 2020 vehicles until April of 2021. Ford literally announced factory incentives on 2020s the day I drove to the dealership to "have a chat" with the Bronco rep.
Admitedly, this past year has been very weird.
Bronc-O
Phoenix
In a normal, situation washing is part of PDI. With these sitting, there's sure to be dirt around the sealing edges of the top and likely some of it will end up under the new seals and lead to leaks or noises.
Monster1926
Indiana
GMC Sierra 2500HD
Your thinking way to much into it. Dirt is supposed to be on the outside of a seal that’s the point of a seal. If your worried about leaks is a removable top vehicle right for you? They all leak
Bronc-O
Phoenix
Dirt under the seals after use is one thing. New, not so much. Since neither of us know what they will do, pointless to argue it.
