- First Name
- Seth
- Joined
- Dec 25, 2020
- Threads
- 7
- Messages
- 419
- Reaction score
- 731
- Location
- Austin, TX (Pflugerville)
- Vehicle(s)
- '19 ZR2 Bison D , '23 Bronco 2DR, MT
- Your Bronco Model
- Badlands
- Thread starter
- #61
Broaddict Single Cross bar for OEM Roof Rack
In Ford's not so bright wisdom offer's a Roof Rack from the factory as an option. However they only give you two crossbars. Normally on most roof racks, this is fine, you get one at the front and one at the rear. However with the Bronco roof rack one bar in 1/3 from the rear and one in the middle. There is no front bar and they want to charge you an additional $200.00 to put a crossbar at the front of the rack.
I found Broaddict on Amazon and saw they sold a copy of the oem bar, and on that particular day it was priced at $66.75 (Currently it's $89 on amazon with a 5% off coupon), so less than half what Ford is asking.
The Broaddict bar is a complete copy of the factory bar, the plastic piece doesn't form as nicely around the Broaddict bar, but seeing how tall most Bronco's are you'll never see it, the only other difference is the 4 bolts provided are silver, where the factory ones are black and branded Bronco. At least Broaddict did use the same T27 size, so you don't need to get a different tool for anything else on the rack.
The Broaddict Bar:
The Factory Bar:
Not bad for less than half the money of the real thing.
The Broaddict Bar:
The Factory Bar:
