- First Name
- Seth
- Joined
- Dec 25, 2020
- Threads
- 7
- Messages
- 419
- Reaction score
- 732
- Location
- East Tawakoni, TX
- Vehicle(s)
- '19 ZR2 Bison D , '23 Bronco 2DR, MT, '24 Lucid Air Pure
- Your Bronco Model
- Badlands
- Thread starter
- #61
Another day, a few more mods/additions.
Front License plate, my dealer was nice enough to call me and ask if I wanted them to install the front license plate mount. I asked him how it was installed and he said into plastic. I told him no, that I would do it. However I found that the factory mount for it, blocked some of the front camera. The only alternate option I found was a mount that attached to the bottom of the bumper. The more I looked at the more I didn't like that ideal. Why would I put something on the vehicle that I would have to take off every time I went off-road? I did see one that mounted up from the skid plate but it covered one front tow hook and a sensor. That was a no go for me.
So the mudflaps I installed came with 4 sheets of foam with adhesive backing. I had the idea to attach the foam to the back of the plate and just zip tie the foam backed plate to the grill. Nothing permanent and if I decide to get the ARB Summit Bumper, I'd have to move it anyway. You can see the top two zip ties in the front camera, but I'm sure I won't notice it unless I look for it.
The bottom zip ties go around a lot of stuff inside the grill, it looks like there are active shutters behind the grill, those zip ties might impeded the the bottom shutter from fully closing, but I doubt living in Central Texas that they will ever be closed.
Also putting on the rear plate, I found one of the easter eggs, I didn't know about:
Sticker Fab 2-door lower door protection:
I tried to install this on the driver's side, unfortunately the door piece is meant to wrap around the bottom of the door, which is something I don't have the knowledge to do. So I used a Xacto knife and cut it, which did work well, but then I noticed that the front didn't look like and the rear piece wasn't cut right, so I just ended pulling it all off. I noticed when I started this effort that I have my first rock chip right in that area. So I'm going to search for some touch-up paint for HPR. I'm also going to find a wrap shop to do the lower doors and the hood. I plan to put the hood rock guard on and some plastic lower door pieces I just want the wrap so that I'm not mounting these things with double sided tape directly to the paint, this should allow me to either remove them or change them out without having to scrape adhesive off the vehicle.
A good friend of mine came by today to check out the Bronco since he's never been in one. I let him take it for a drive and he was really impressed. I promised him I'd let him drive it off-road.
