Taillight retainer push pin part #
bigdedition
Moyock, NC
2022 Ford Bronco, 1985 Ford Mustang
For the installation/replacement of taillights the 1st step is to remove the pesky pushpin retainers inside rear door, does anyone know the part #? I can't find it on Ford, probably nomenclature is different. I want to order a replacement from Amazon that will fit correctly. I may have destroyed a couple due to my muscles! LOL
Gene Dios
Atlanta
Do you mean these?
https://a.co/d/a1cBSK9
Correct, they look like those. I don't see that Bronco is listed compatible for the ones in your link though.
Those Should work - 1/4” / 6.3mm is the pin size and that link is that. Fender clips are just broadly compatible so I wouldn’t get hung up on if Amazon says it’s compatible or not.
If your taillight is stuck hanging out waiting on this you can steal one from a fender liner - which is easy to replace when you get the part in
bigdedition
bigdedition
Moyock, NC
Thank you both for confirming!
Alfa
Diego
Austin, TX
Bronco Wildtrak
W715694-S300
Quick question: When I look these up online at Ford dealers, they are around $6-7. Does anybody know if that is for 1 item, or is that a multipack?
Ducati1098
That is for one clip
