Tailgate table install
Rednek
Jimmy
Northern Alberta
here is an easy DIY project you can do in an afternoon in your driveway,enjoy the first of many adventure camping upgrades to "Bucky"
campbebc
Ben
Waterford, VA
2021 Ford Bronco, 2019 F-150 Raptor, 2004 Mazdaspeed MX-5
Excited to have some install videos coming out for parts sitting in my garage, sans Bronco. Thanks for sharing
Mdh186
PA
Truck
Ouch - drilling and rattles. Two of my larger concerns. Guessing corrosion isn’t an issue with aluminum? Seems like they could’ve put something in to avoid rattles from the factory. Oh well. Undecided on something I really thought would be nice.
Rednek
Rednek
Jimmy
Northern Alberta
rattle was a easy fix,and like i said drill the first holes to get the crying over as there will be many more in future lol
deanfromkelowna
Dean
Kelowna
2018 F150, Tesla Model 3
My Bronco is my fifth convertible. When I see someone concerned about rattles it reminds me that someone hasn’t probably owned a Wrangler, BMW or Porsche convertibles. My Wildtrak is simple a fine vehicle for what it is. Thanks for the Video Rednek, I have the table but delayed to install it when I saw the drilling steps. This helps me realize someone else has already drilled into theirs. And, in Canada!
Southside_Ray
Ray
Iowa
2014 Ford Fusion
Looks like you have a sas? If so what is the height of the table off the ground when folded down?
skithebadlands
Doug
New Jersey
2018 BMW 340, manual, AWE exhaust, MHD tune
Thanks so much for the video. The supplied instructions leave a lot to be desired. Took me about 2.5 hours working slowly and double checking my work while watching your video. But now I could probably do another install in 20-30 minutes. In the instructions I received as well as your video I couldn't tell if the rubber tubes (the ones with the glue inside) go on the top edge or bottom. In the end I am pretty sure the top ones go on the top edge and the bottom ones (the long ones) go on the bottom edge. It's not intuitive at first but if you try it you'll see why that is probably correct. It has to do with the direction that the table mount fits through those slots in the tailgate. The rubber edging is to prevent metal on metal contact. I think it's correct feel free to prove me wrong. As far as the concerns that others have raised regarding the bolt length that is not an issue. I think any damage to the outer tailgate metal is due to the drillbit. I didn't use a stop but I've got pretty steady hands. Don't push the drill. Just be patient and let it do its thing slowly. And thanks for the tip regarding starting with a much smaller drillbit and working your way up to 7/16th. Worked like a charm.
Ford Bronco Tailgate table install 20211117_225239
Ford Bronco Tailgate table install 20211117_225713
Ford Bronco Tailgate table install 20211117_225814
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
I like those collapsible bar stools you got there. Where’d you pick those up?
skithebadlands
Doug
New Jersey
A little store called Amazon! They hold like 350 lbs. Search them up. You'll find them.
Jer
Jeremy
Oklahoma
2021 Badlands,2017 F350, 2023 F150L, 1976 K20
I installed the same table last week. No rattle at all for me, even on these terrible OK roads. I have a 2 dr, but doubt that makes a difference. Nice write up.
Jim Walter
Athens Ga
2015 JKU
Does anyone know if the table would interfere with the storage (fixed lid) when the door closes. I have ordered both (no Bronco yet).
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
It sorta kinda does not interfere. Sounds like you have to remove the rubber stripping off the lid in able to close the tailgate. I’m waiting to find out if there’s room for a thinner piece of rubber there, or some way to create a seal.
