T
cashe3
Charles
Atlanta
Hyundai Santa Fe
Add me to that list. News, sports talk, or audio books. Bronco doesn't even have music channels on the presets
you and my wife are the only humans I’ve heard of who don’t listen to music in the car. Driving + music is one of the most enjoyable experiences in my life. Y’all are weird.
Edit:
And to add to the conversation I have EG nipple rings on the front cause they look cool. Soft shackles in the recovery kit if I need them.
popo_patty
Caleb
Sacramento
2021 Bronco/1996 Jeep XJ/1957 FC-150
Been wheeling for six years on the Rubicon in my Jeep and now my Bronco takes the reins. I wheel so often that I just leave my shackles on. I used to do recovery on the side and it was just easy to leave them on plus have a few spares in the bag.
No rust issues yet. If you’re worried about them freezing on then you don’t use them enough ;)
There isn’t anything wrong with either opinion. You do you and don’t worry about what other people think.
35tires
35tires
'23 Bronco, '21 4Runner
Looking at your photo, from a strictly visual perspective, the two protruding eye attachment points look a bit unfinished or whatever. Like you should have a tow bar attached.
But regardless of having them bare or with shackles, from a usage standpoint I don't like having anything protruding like that, regardless if a shackle is attached. Because there are times I use my 4x4s to push other vehicles, or get pushed if having an issue. And it's easier to do that if your bumpers have a clean flat mating surface. Those eyes sticking out are going to damage and otherwise make pushing things more difficult.
I am adding an s8 light bar to fill in a bit, but I agree, it is a very unique look. Would I buy it again? For the price it is amazing and it will do the job. If I had a looser budget I'd have gone ADD just due to fit and finish.
88to21bronco
Tennessee
2017 Nissan Titan XD
And I’ll add—my shackles are under the seat.
FloridaBurgBronco
Don
Middleburg, FL
'24 4Runner TRD, former '22 Bronco Badlands owner
Actually, a Factor55 Ultrahook would be perfect for your setup....no need for the hook you have, flush with the fairlead, protects the winch rope from damage/exposure, etc. Keep the D-rings inside and at the ready for any recovery.
BTW: always test the winch before you wheel, can't count the number of people I know who are excited to use their winch for the first time, only to discover a bad connection from lack of use.
I get what you're saying, but the end of the rope is covered/protected by an additional slip over wrap/cover the whole way to the shackle with little to no exposure. And the winch itself and the rest of the line are covered up by a winch cover...because it's synthetic. Pic was taken without cover, but the cover makes it look not as cool🤣. Same reason I like the hook on the shackle, coolness factor, at least I think it looks cool.
Couldn't agree more on the experience and being ready. Once mine was installed, for general use and specifically for the trip I'm on now in VA, where I don't have a wheeling buddy. I took it out with another Bronco and Jeep buddy to play with in our local, next door forest and before I could do some mock recoveries, my buddy gets stuck and we pull him out. Later on the trail, I do a single, a double line and a directional pull just to familiarize myself with it's operation and to check to make sure it's overall trail worthyness is there. Great so far. I will have to work on my attempts at getting the line back in there as beautiful as it came from the factory😂. It's not a rat's nest now, but it doesn't look perfect by any means. But I don't see any reason to carry additional gear inside that can otherwise be mounted outside. I don't think having shackles mounted outside says mall crawler at all. Now maybe the colorful ones do🤔😉
FloridaBurgBronco
Don
Middleburg, FL
Maybe through the hole the shackle is attached to 😎
Doesn't fit there, but again, I don't see any reason to not have the shackles mounted on said holes, zero reason to not mount them there and be ready to use.🤷‍♂️
HoosierDaddy
__ Eric
NW. Indiana
I half agree too. I just wondered. I’m also looking at doing a voodoo ropes soft shackle package with the rope and everything and calling it good.
I just know not having a winch (I’ll add one in the rear but that’s a ways off) I will need to make helping me as easy as possible for all parties.
west Texas is pretty unforgiving.
I keep the shackles off the rig. Unless they have the safety pin to keep the bolt from backing out, they shouldn't stay on there full time.
When I first started off roading, I set up a recovery bag with a nice assortment of straps (snatch straps, tree saver straps, hoisting straps from work) , couple pair of leather gloves, various shackles, even a quality recovery snatch block.
Next time you see a heavy duty duffle bag at a garage sale, for a few bucks, there ya go, it's a start.
The duffle bag has a spot on a garage shelf with other gear, so if a trip is coming, prep and load up is a bit more efficient.
I may not have a winch, but I have some nice gear to help out either myself or others.
woodysfj40
woody
SW Utah
www.instagram.com
BJ74, FZJ80, NCV3, JHF
In my environment, there are rocks and stuff to hit as part of working thru a trail, and the rope can end up damaged from contact (well, and 100+ sunshine). Run that exposed rope into a rock a few times, and you'll need the Factor55 fid kit for a field repair.
Couldn't agree more on the experience and being ready. .... Later on the trail, I do a single, a double line and a directional pull just to familiarize myself with it's operation and to check to make sure it's overall trail worthyness is there.
Awesome! Experience for the win, and good on you for actually working to understand the gear BEFORE you need it. I am "official" recovery for Trail Hero events, and have been doing recoveries for 30+ years...practice helps keep recoveries fast and clean. I've had some entertaining ones ;)
So, tip: I run my synthetic winch lines at 80% capacity, so a winch that normally holds 100' of line now has 80'. Lots of reasons for it, the two biggies are: 1> the max capacity of the winch is the 1st/bottom layer, so you are more likely to be winching with the max power since most recoveries are short/close pulls, and 2> Less likely to overspool one side of the winch during a recovery - I have witnessed "exploded" winches when the operator kept winching, even tho the line was bound up on one side of the drum. Pretty rare that a line winds up perfectly during a recovery, and equally rare that your anchor is perfectly straight ahead.
Add a 50' extension line to your recovery kit for longer pulls.
helifino16
Ron
Mount Sinai, NY (Long Island)
Go all Black, it hides them well.
Ford Bronco T Blue lights off
35tires
35tires
[/QUOTE]
I need a friend like you! I am new enough that I'm pretty worried about getting stuck and not having a winch going way out in the desert the only safety I have is a sat-nav phone but you never want to use that in an emergency. I also have a shovel and I'm building a 'get me out of a hole' bag but I'm lost on what is needed vs what is just being upsold to me.
I intend to do a rear winch down the road, but until then it's all hopes for a passing car and enough tow tools to have them pull me out of a bad spot.
FloridaBurgBronco
Don
Middleburg, FL
[/QUOTE]
Yes sir, I do appreciate the extra info, I am still new to be up front, so I appreciate your info. I do have an extra flat strap to extent the winch rope. I have been watching a few of the "more decent" YouTube channels trying to get some free education about the use and misuse of winches. I think it's good to see the good and bad, reminds of to NOT do the bad. I was wondering about the spooling too as you use it on a long stretch, because unlike, say my air hose for my compressor, it doesn't have an automatic feed side to side to keep it even on the drum. I had only goven that some thought, with your comment, I'll pay more particular attention to that and like you said, try to run an extension whenever I can. To be clear, even though I'm new to this, I still want to know the right ways to do things. And I also get that winching can be very dangerous, even when you take precautions.
woodysfj40
woody
SW Utah
www.instagram.com
IMO, a rear winch is near useless....I have one on my comp crawler to suck down the rear suspension,, but it will never be used for recovery. In 30+ years of wheeling I've had TWO situations where a rear winch was needed, and in both cases I ran the line under the vehicle. Each needed a short backwards pull to un-jam the front and then a front pull to winch to the side and clear the obstacle. Both were in snow :)
whiteox
Tom
Illinois
2022 Bronco Base
I'm running the JCR Crusader front bumper and it looks a little odd being so slim and close with the shackle mounts sticking out a good bit. I like it for the high clearance but I'm wondering if shackles would add to the look or just look corny. Here are some pics for reference. You can really see it in the 3rd pic.
View attachment 531667 View attachment 531669 View attachment 531668
You Sir, have too much time on your hands. Leave them on and worry about more important things like where next adventure is going to take you and yours in that beautiful Bronc! Tommy Bronc
woodysfj40
woody
SW Utah
www.instagram.com
The flat snatch strap stretches. Beats nothing, but less than ideal for static recovery. The BIG issue is if something "breaks" in the system, that stored energy can cause major damage (which is why that flat strap works so well for snatching purposes). Synthetic rope has an extremely low stretch (versus steel cable, or recovery straps). ARB used to make a flat strap specific to winching (purple I think...)
Be careful of the Youtube...their goal is video views and happy sponsors, not necessarily accuracy :)
The BEST source for education/training is the International 4WD Trainers Association. I had a good handle on my recovery skills (trail and error) but did some training with them back around 2007/2008 and definitely picked up additional tips. There is no better learning method than hands on. I've taught a few intro101 classes too, but 60 minutes of me blathering to a crowd isn't much good without a few days of hands on.
