Synthetic oil recommendations?
Dialtone
Twilight Zone
Bronco Big Bend Mid
The NAPA Platinum is a Wix filter so price shop. I've found O'Reilly's to always be more expensive in my area.
MadMan4BamaNATL
Ray
Atlanta
After engine break in, going to full synthetic oil. Looking at Amsoil , used Shell Rotella in my old F250, had no issues. Any thoughts? Thanks folks.
Not sure if anyone has said it, but please ensure you only use an oil that is certified by Ford for your engine.
I know feelings about oil and oil brands can be all over the place, and I am in the AMSOIL camp for off-road and Castrol Edge full-synth for my old BMWs, but I use Motorcraft Full Synth because I purchased a package when I bought the Bronco.
Motorcraft is actually good oil and a great synth, so don’t discount it. No matter what oil you drive, just change within 5K miles.
I go off-road, so I keep on schedule. The certified list is in the oils and fluids area and think it’s a sticky, so download it. There is a certain AMSOIL that is on the certified or approved list, but not all. While under warranty, best to stick to that list.
Good luck with whichever brand you go with.
HBTFD
Newnan GA
F350
Mobil 5w30 synthetic every 5k. Summit had it for $16.xx per 5 quart jugs a few weeks ago.
Lou-Q
Lou
Florida Keys
90,19,24 F250 15 mustang Gt 50th ann. 2020 gt 500 and waiting for our GTD.
I've been a Mobile One camp for a while, but I freely admit, if something else is on sale I will strongly consider it.
Pretty much all the name brand synth oils are going to far exceed what you need anyway and are certified.
I second Mobil 1. I've been using synthetic oil since the early 70's. Back then they called it "snake oil'
I had to buy a 24 can case at some warehouse in Chicago. Then Mobil 1 came along and was much easier to get.
For sure use a Ford filter (they have the patent), every other one is a little different.
My hot rod Ford diesel mechanic told me that.
We have three diesel Fords and I use Rotella synthetic.
On our gas vehicles I use Mobil 1 other than the old Caddy and old Vette, which I use some racing oil with high zinc . As a conclusion I agree that they are all about the same and they save your engine.
Lou
Dialtone
Twilight Zone
Bronco Big Bend Mid
Is the Ford filter really that big a deal? 30 years of owning vehicles using various makes of oil filters and no engine wear issues.
It's really only a big deal if you're under warranty. Something goes south in your engine they will have an easy out on the repairs if they see an off brand filter. Even if it probably is a rebranded Purolator filter. Don't know if that still true but it was.
MLRey
Lancaster, CA
21 Ford Ranger Lariat FX4, 18 Subaru Outback
I go with the Pennzoil Ultra Platinum. Get the three 5 quart case from Amazon for between $80 and $90 which is a good price. Use it for all but my daughters VW. In all the reviews I've seen it's one of the best. Doubt you can go too wrong with any of the synthetics mentioned. I have used Mobil 1 and Amsoil. Amsoil is good but the most expensive even with discounts. Used to get Mobil 1 at Walmart but hate going in there anymore. I can get the Pennzoil delivered for about the same price as the Mobil 1 so it's my current top choice.
CarbonSteel
Colorado Springs
2023 Carbonized Gray
FRAM Endurance FE-11955. Full synthetic media and highest efficiency rating a.ong similar filters. 99+% @ 20 microns.
As for oil, you will gain more by maintaining a reasonable oil change interval.
CarbonSteel
Colorado Springs
No, in fact, it is less efficient than most of the aftermarket brands.
hotrodtim
TIM
23 F-150-RCSB 22 WILDTRAK 19 EXPED. 68 BRONCO
Amsoil is my choice in both our Wildtrak and Expedition , costly but for longevity and our investment 😎
wjtinfwb
Bill
Destin FL
Jeep GC, Excursion, Focus ST, Subaru Crosstrek
I miss the days of running Rotella 5w-40 in my 94 TT Subi.
You’ll be fine with any quality Syn. Im of the opinion that Amsoil is far overrated for a daily/street vehicle. It will never be pushed to the limit or endure the conditions to warrant the cost. But to each their own, you won’t be making a mistake going with Ams.
Stick with something that matches or exceeds spec, something that protects against LSPI and you’re golden.
Agree. While both Bronco engines are turbocharged, it's not like they're built up race engines with huge boost or some other stress adder. Look for the Ford spec on a full-synthetic 5w-30 and focus more on a 5-6k oil change interval rather than the brand of oil. For the record, I use Castrol Full-Synthetic Edge 5w-30, mainly because its available anywhere including WalMart and usually for less than $25 a gallon. I'm a believer is trying to use the same brand and type of oil as consistently as possible. For filter, I use the OEM Motorcraft, I buy them off Amazon for about $10 bucks each, usually 2-3 at a time so I always have a spare. They come with all the needed o-rings and I trust Ford to have spec'd a filter that will easily exceed the engine's requirements. There's also a limited selection of these cartridge filters available, unlike the spin-on filters we're used to seeing. Use something that meets the spec and change it every 5-6k and you'll have nothing to worry about.
wjtinfwb
Bill
Destin FL
Interesting. That Fram Endurance, from the pictures, looks remarkably like the OEM Motorcraft High-Performance filter used in the Mustang Shelby GT500. It shows them available at WalMart for $12 bucks, I'll pick one up next time I'm forced into that Hell Hole and take a look.
Razorback
Bill
Dallas
Lincoln MKX
Been using Amsoil since 1000 mile 1st change.
Chritaka
DFW, Texas
'23 WildTrak; '06 Whippl'd Mustang (sold4upgrades)
I used to use Castrol before full synthetics became widespread, and never had any issues. I used Royal Purple full synthetic in my 2006 Whipple supercharged Mustang, consistently and from the first oil change. It ran great up until I sold it a year ago. RP is expensive and the Bronco isn't seeing those same levels of demands.
I currently use Valvoline Advanced and EL, but they don't get much love. We have run Adv. in the beginning, then later EL in our last 2 Jeeps and never had an issue. I'm just now coming up on my second oil change in the Bronco, but I did Valvoline Advanced on my first. I do believe in trying to be as consistent as possible, seals and engine internals just seem to be happier with consistency, and that's just what I was taught growing up. I was also taught it's always better to do your own oil changes so you can ensure it's done right, too many nightmare stories otherwise... I do have a backup shop that I trust if I simply run out of time, but I won't take them anywhere random.
I also like to use WIX filters as that was always recommended by my racing buddies. If I have to take it my trusted shop for the change, I bring my own filter as I don't like their in-house.
Like it's been said, proper OCI (oil change interval) is probably the most important factor with these engines, aside from meeting Ford's spec.
For reference:-
Sticky: Bronco - Motor Oil Compilation List that meets Ford Spec WSS-M2C961-A1
