Swing Gate Strut gives up the ghost
Catmandu
SW Florida
2013 Jeep JKU (Officially Sold), 2015 Expedition
Correct, female threads are merely polymer. there doesn’t appear to be any metal reinforcement within the end swivel cap as far as threading goes. If you zoom in on the first pic you can see the plastic within the male style threads
This may actually be designed this way on purpose as this makes a serviceable breakaway point. If this was stronger it would shift the issue to the tailgate panel itself resulting in a more expensive repair. I am in no way shape or form defending Ford's engineering choices, but coming from the Jeep world, I am concerned about the strength of the aluminum tailgate panels and the weight already applied by the spare tire.
DWood
DWood
Dustin
North Florida
Well let’s hope they accounted for that and stocked up on them. However if it breaks away when the vehicle the leaned to the passenger side the area where the hinges are attached to the swing gate will take all that shock loading. Not to mention If there happens to be a hard object before it reaches full opening
Rubicon 2 Badlands
San Ramon, CA
2008 JKU Rubicon / 2021 Bronco: Badlands/Sasquatch
I like the idea of installing a limiting-strap. Something to look into.
95Bravo
Dallas, TX
2011 F-150
@DWood , I had the exact same defect and it happened the same way - pulled the tailgate open and the vinyl threads from the strut "head" stripped off. Vinyl threads, @Ford Motor Company , seriously?
I hope your dealer fixed it. But when I called my dealer, they said the part was back-ordered (which I took to mean either (1) this problem is happening a lot, or more likely (2) extra parts are not even available yet).
I emailed Redline Tuning (they make a killer set of hood struts for our Broncos), and sent them pics of the part failure. They make a "head" that is the same size with metal threads!! And fairly priced at $10 for two. I threaded it on, popped it back in place. Good to go!
Here is a link for anyone who might need it in the future: https://www.redlinetuning.com/product-p/72-00006.htm
DWood
DWood
Dustin
North Florida
Cool thanks and yes dealer replaced it, took about 3/4 weeks for it to come in.
da_jokker
Jeep Wrangler JKUR
Bookmarked! Metal ends imagine that!
Fonz54
Lou
Monterey, CA
Jeep Commander, Porsche Cayenne, Mercedes C250
Thanks just ordered a pair to have in my spares box!
Mike777
San Antonio
Ford Bronco, GMC Terrain
Rosalieee
R
LA, CA
Raptor, BMW M3 Competition X-Drive
Does anyone have the partner number of the replacement strut?
adam1991
VW GTI (2)
Coming in late here. I got the soft top lift assist struts plus the hood struts, all from IAG; I couldn't help but notice that on the rear, it used the plastic ends with the captive push-on clip--but for the hood, they used something different with the slide-in pin to hold it on.
When I asked, they explained how the captive push-on clip is for the plastic ends, while for the hood application they used a different strut with metal ends, a better application for a hot environment like under the hood. Those metal ends require the slid-in pin.
I was happily learned. So I looked; my '23 swing gate has struts with the plastic on both ends, complete with captive slid-in clips. I won't complain if that is a sacrificial piece to save the swing gate metal from tearing. It looks very easy to replace.
And I agree on a limit strap. In fact, I'd be OK if that strut were just a strap.
I thought the same thing until I parked facing uphill one day
My strut keeps popping off at random times, and it nearly knocked me on my butt. Fortunately I have a spare tire reinforcement that has a hard metal stop to keep the tailgate from crashing into the brake light (similar to what a strap would accomplish), but man it hit that hard and rebounded off pretty good.
It took some mighty heaving to get it closed again. It was a pretty steep hill.
That tailgate is a heavy mofo with my spare on there
