Sudden stop, bent hitch.
Sooner
Ted
Henryetta, Ok
69 F100, 56 CJ5, 11 F250, 17 F150
Think this is too much?
Ford Bronco Sudden stop, bent hitch. DB9B19B4-D68F-48D3-AAE5-731FFDE82F7A
F OR D
BD Green Machine
With that big of a drop hitch I think you were way over the tongue weight rating.
my guess too. not saying it should have happened but see why it could.
may have needed a reinforced drop hitch since you are pulling max tow on that lift with a big drop. if you get it straightened out look at bulletproof or similar.
J Jernigan
Jody
South Bend Indiana
2022 F-150 Platinum, 2022 Ford Bronco Badlands
I’m going to guess no trailer brakes?? Trailer brakes would of likely prevented this from happening as the trailer would of been able to provide some stopping power of its own as opposed to placing all of the pressure of stopping on the hitch When you slammed on the brakes.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
JakeC
Jake
Dearborn, MI
michiganbroncos.club
2022 Badlands
Since you were close to max tow capacity the 6” drop hitch likely created enough leverage to bend the receiver.
^ This
dgorsett
colorado
F250, Mustang, Explorer
Damn, this post and the other one make it hard to understand if that cross member is weak or if folks are just putting too much pressure on that cross member.
Both, apparently...
The Pope
1977 F250/2007 Mercury Mariner/2014 Infiniti Q60x/2011 Kawasaki C14
Once the next gen Ranger is out, there should be something like this that might bolt up on the Bronco. Which would be a Much Better setup that the current offerings.
Ford Bronco Sudden stop, bent hitch. Snap14
cashe3
Charles
Atlanta
Hyundai Santa Fe
Still no pics. I smell trollpost
1970AMCAMX
Robert
Titusville, FL
F150, AMC AMX, DF Goblin
I would not doubt it if we start seeing more of this, if the Bronco is lifted and a drop hitch is used it is creating a large torsional force on the hitch/crossmember which needs to be taken into account when considering the weight of the trailer being towed. This is also going to happen if a long hitch extension is used with the tongue weight is at or near maximum.
A weight distributing hitch can also cause this if spring bars are too stiff (don't use one that is rated for 800 pounds, there are plenty of choices in the 200-300 pound range)
