Stock Sound System is Great!!
Bellime
Keith
2022 Ford Bronco
Yup, you read it right:
The stock sound system sounds excellent IF -
1. You play Pandora source material using Apple Car Play and
2. You select the driver side only equalization sound setting
Try this approach BEFORE you knock the sound. It is a hidden gem worthy of a Virtual Easter Egg.
As many have observed, the standard system sounds poor if you do most anything else.
Try 1 & 2 before you upgrade. Lots better places to spend scarce upgrade $$.
You all are welcome ;-).
PS Best of luck to the early reservation holders still awaiting your Pony.
It’s definitely worth the wait no matter your chosen configuration.
You will probably notice an improvement by adding sound deadening behind all the speakers.
Jorvin
Jordan
Calgary
2024 Bronco 4 door
I can't believe I never heard about this before?! I looked at tons and tons and tons of Bronco Audio forum posts, and YouTube videos, and never once heard mention of this. I just got my 2025 Badlands and found the "Driver" occupancy mode. Wow. 1 seat tune. I wonder how much it actually changes. Enough to make a noticeable difference.
I don't know how much else they improved the system or sound deadening (as advertised), but the base audio system is seriously decent. I bought some Hertz DCX 100.3 speakers to swap in the dash, which was the easiest audio upgrade known to man with the metra adapters from crutchfield. Seriously impressed. I can't believe that's a 6.5" subwoofer back there. Just turned down the treble and midrange 2/3 clicks, and went through some test tracks.
Not sure I will upgrade anything else honestly... Very Happy for now.
superchar1982
Charlene
west sacramento
2024 2dr bronco 7spd , 2022 911
I’m going to try this, but can someone explain what pandora source material is? How do I get it or get to it? Thanks
