Intermittent sound system buzz
Desert-Pirate
Austin, Texas
Porsche Macan S and Toyota Highlander
June 2023 Bronco Sasquatch Wildtrek build - with in the past week the sound system has been having intermittent buzzing (stops, starts, shifting forward, reverse, etc…) that clears up after a few seconds. Anyone else having this issue?
MileHighCitizen
Al
Denver
Bronco 2D 2.7
Do you use CarPlay/Android when this happens? in general that sounds like a grounding issue, if your system is stock the dealer will probably have to fix it.
Desert-Pirate
Austin, Texas
Stock system and while using apple airplay. North Austin Ford dealership is 2 months behind on work.
MileHighCitizen
Al
Denver
Bronco 2D 2.7
I would turn off Bluetooth on your phone and try it wired in to the USB plug in the center console to narrow down the problem. If that doesn’t fix it than it’s likely a head unit problem.
Desert-Pirate
Austin, Texas
Yeah, the buzz happens with and without USB. Any ATX area members recommend a dealership?
