Stereo upgrades?
BW BRNCO
BW BRNCO
Brent
2025 Bronco
BW BRNCO
BW BRNCO
Brent
2025 Bronco
It’s actually pretty complex and like another user suggested fairly expensive to upgrade your system. First thing is it the B&O center channel sub system or standard 6 speaker. I have 24 Big Bend SAS, non B&O system.
There a number of ways to mod, I would stay away from the kicker 200.4 plug and play system that is out there. The front dash speakers are wired in parallel to the side panel speakers below. So the resistance to these speakers are 2ohms if using factory wiring. I rewired my dash speakers so that they are now 4ohm load. Kicker 200.4 doesn’t drive 2 ohms without overheating. It’s easier to find an amp that drives 4 ohm loads, and factoring limited install space behind the rear cargo side panel and that a sub is totally necessary to complete the upgrade and that you need a DSP to correct sound. Also need Forscan to turn of the factory EQ and send full signal to the outputs, as the rear pods when upgraded to 6.5 coax will not get proper signal until Forscan used. So the pod upgrade isn’t worth much until Forscan is used. I used the Apline PXE C80-88. 8 channel amp with DSP. 50 watts to each 6 channels at 4 ohms. 150 watts for channel 7&8 output to sub. I used a dual voice coil SSV SUB and rewired each voice coil separate to get 4 ohms to each voice coil. I used sound deadening panels from Amazon. The entire result is amazing. I love it!
Its the standard 6 speaker system, thanks for your information, very helpful.
23OBX2.7
AB Canada
2023 Bronco
You have rhe easiest uograde with six speaker a decent dsp amp controllong a cheap no name 1000W sub amp, and a suie of Audison AP speakers and sub or whatever prenium can get on marketplace or doymobile audio and youre good to go.
Fly by Nite
Walt
Pa
You have a 2025 right? A 2025 has a 7 speaker system when you count the subwoofer.
2021 and most 2023 had the 6 speaker without subwoofer. Subwoofers became standard in 2023 but Ford quickly ran out of them, so they installed non-functional subwoofers and amps! Those are easy to upgrade, but if you have an earlier 6 speaker system it's more difficult.
BW BRNCO
BW BRNCO
Brent
2025 Bronco
OK, thanks for the information.
tedstriker
Houston
2025 Bronco Heritage, 2025 Colorado ZR2
Just bought a Big Bend, think has basically the base stereo, sound quality is horrible. Has anyone upgraded speakers, amp, without compromising the whole unit/rest of the screen’s infotainment systems? Live in Houston area.
I'll let you know how it goes with my wife's Bronco Heritage. It too has the base sound system and I am upgrading it in a month or two with an entire kit from TrailSeven. Replacing everything...speakers, amp, dsp and subwoofer.
23OBX2.7
AB Canada
2023 Bronco
Trail seven have a great offering from vids to proven kits, at a super premium VS assemble yourself. Go with mid to high priced kits like Hertz and Audison, worth it for the two year warranty and excelent tel support alone, in addition to quaility and durability.
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Friends never recommend Kicker to their friends! lol
B&O with MoBridge Amp/DSP, Hertz Cento Speakers & JL Sub in a modified stock enclosure...Absolutely
Ford Bronco Stereo upgrades? tune 7
EPIC!
Seth
Houston
2024 Bronco Wildtrak 2015 Explorer Sport
Did you settle on anything? I am also in Houston and looking to get new speakers, amp, pods, etc...
23OBX2.7
AB Canada
2023 Bronco
To keep it simple with great outcome I suggest mobridge + all Audison AP and APX swapping like for like and the Audison 10" enclosure or Hertz MPBX300 enclosure tailgate mount w brackets and rivnuts pls do the deadening and absorbing with resonix.
Nibroc99
Corbin
Rochester, MA, USA
www.corbonthecob.com
2022 Wildtrak: The WildeBeast
Joe
Bronco 2 door basesquatch
I have a 2023 big bend with the 7-speaker system. The factory sound is terrible. I had Alpine R-S65.2 in the SSV pods for years. Excellent sound with the Kicker 200.4 driving them. Then I started to realize I was missing soaring vocals and horns on rock, pop and jazz music. The Alpines play loud but not quite bright enough. After a lot of research I purchased a pair of Focal PC 165 FE. These are far superior to the Alpines in terms of sound and build quality. These babies check all the boxes and I will keep them if I ever sell the Bronco. That is how impressive they are. The Focals fit perfectly in the SSV pods and complement my JL Audio Stealthbox.
Folks want to stay within a budget I understand but it must also sound good. My budget system cost me around $2500. I have spent many hours tuning my system to my needs like everyone else here. 😉
