Steps that attach to rock rails
Trek0045
john
pennsylvania
Ram Rebel
Does anyone know if the steps that attach to the rock rails on the Bronco are the same as the ones that attach to the Ford Rangers rock rails? They look identical
MileHighCitizen
Al
Denver
Bronco 2D 2.7
The OEM ones dont attach to the rock rail, they are a single unit that bolt to the Bronco from underneath. I have no idea if theyre interchangeable though.
Black_Stallion13
Cincinnati
Tacoma
As stated above - the hoop steps and rock rails are not compatible (I have both and swap them back and forth if I go on an off-roading trip). The hoop steps come with their own mounting bar that looks similar to the OEM rock rails, but are not as heavy duty.
The Ranger hoop steps and Bronco hoop steps have different mounting points so they are not interchangeable even though they look almost the same.
Best steps for factory rails I found were the AR Stirrups but I don’t think they make them anymore and were way too much $$$ to justify anyways, IMO.
Trek0045
Trek0045
john
pennsylvania
Ram Rebel
The left is the ranger and the right is the bronco
Ford Bronco Steps that attach to rock rails IMG_9588
Ford Bronco Steps that attach to rock rails IMG_9587
bkirchhoff
Middlebury, VT
BMW: '07 328xi, '13 X1, '75 R90/6, '12 R1200GS
If you are looking for a step that mounts directly to the OEM rock rails, you should check out these from iAG:
https://iagoffroad.com/iag-full-length-ez-step-add-on-for-2021-ford-bronco-1-pair-/
I have a pair on my 2 door Badlands and love them. Install just takes a couple of minutes. Makes it much easier for my wife to get in and out. And they come off by releasing 2 bolts per side when you want to hit the trails. Added benefit is that they are full length, so they also greatly cut down on rock hits to the doors.
Black_Stallion13
Cincinnati
Tacoma
Every time I see a Bronco with the IAG steps they are already starting to rust and look like crap.
Badsquatchman
Brent
Maryland
motorcycle & 93 Z28
I like my IAG no rust almost 2 years
Ford Bronco Steps that attach to rock rails IMG_1141
retiredarmymp
Steven
Whitehouse, Texas
2021 Bronco Badlands Sasquatch
I’ve had 5 different steps on my Bronco in the 2.5 years I’ve owned it trying to figure out what works best for me. Just recently I put on a set of Bronco Raptor rock slider/steps and I finally found what I was looking for.
Ford Bronco Steps that attach to rock rails 13B7B00F-7DD5-40EE-8869-AD8E840CC424
EasternSierra
Sacramento metro, California, U.S.A.
2025 Bronco Badlands 4-door 7MT, 2023 Ford Transit Connect van
Have you been taking them off for off-roading, and if so how does that go?
retiredarmymp
Steven
Whitehouse, Texas
I haven’t been offloading since installing them, but I just took one off and took about two minutes. If I was off Roading and needed to remove them, I would store them on my Hooke Road half roof rack with pipe insulation (to prevent damage) and bungee cords.
Ford Bronco Steps that attach to rock rails IMG_7176
TheZsdad
S.E. Tennessee
Explorer ST
Do you have a part number for those? I've looked but have not found them. I'm about to pull the trigger on a 2024 WT. I don't care for the tube steps ford has for the WT. thanks
SeptuagenerianSasquatch
Randy
Massachusetts
Two years in central New England, lots of salt applied if there's a hint of snow. No rust. Very convenient, I can remove or re-install them in ten minutes, fifteen tops. I went for the full-length, which help protect the lower body more. (4-door) (I have RokBlokz mudflaps, too.)
No rust so far.
Their customer service is excellent. I needed a few replacement fixtures (my fault); they sent them gratis.
PayHeedKU
Kansas
2025 CRV, 2000 Dodge Dakota, 2025 Bandlands (ordered)
Do the Raptor Style Boards attach to all of the OEM rock rails, or are the rails you get when you order the running boards specifically for them?.
I’ve ordered a 2025 Badlands but wanted the modular bumper so I couldn’t get the running boards but would like to add them down the line. Will that be possible with the rock rails from the factory?
Randy
Massachusetts
It may be helpful to distinguish clearly between steps (or running boards) and rockrails. The Badlands comes with good, sturdy rockrails, which protect the outboard corners of the body from trail damage. That's all they do. A number of vendors have removable steps/running boards you can attach to the rockrails (see my post, above).
You can find many products that are both rockrails and steps, which will attach permanently to the frame. These solve the problem for models which don't have rockrails. The problem is, most of them don't have as wide a step to put your foot on, and usually the step is fairly high--a problem who need an intermediate height to get their footing on. That could be a real issue with the higher Raptor lift. If it's serving as a rockrail, then you don't want it hanging down low, where it will get caught on obstacles.
My suggestion is educate yourself, searching "Badlands Raptor rockrail step" and see who's offering what. Then you'll know you want.
PayHeedKU
Kansas
I understand what the Bandlands comes with and the difference between rock rails and steps / running boards. My question is can the Ford OEM Raptor Style running boards be attached to the OEM rock rails that come on the Badlands even if they are not part of the factory order.
I guess my question is how do the Ford Raptor Style running boards attach to the rock rails? When you include the running boards as part of the order from the factory is there anything unique about the rock rails that allow the boards to be attached vs the rock rails when the boards are not part of the order?
