Steering control module failure
Ground_zero298
Scs michigan
Recently blew my 2.0 rack. 22 bad lands. Installed a bb 3.0 pre programmed for plug and play. Which worked when plugged in.
all controls on the steering wheel are dead now. horn still works, no lights on dash, still drives fine. (Left right bank codes)
Would this fall under a fdrs module update or should I be looking into something else? And if module related which specific one should I be going after. Have procal, forscan, and fdrs.
I made no changes to anything when I swapped the rack computer wise.
Any help would be much appreciated
thanks.
Ground_zero298
Ground_zero298
Scs michigan
The guru for stage 3 steering upgrade is @BigMeatsBronco?
Just wondering, how did the 2 rack go out?
Messed it up on drummond island. Felt like I chipped a tooth and started getting louder over the next 2 months. Was gonna wait til
Fall to replace but failed before that. Full lock up centered. Had to beat the wheels to break it loose to drive home.
short answer is I turned the wheel to hard when it didn’t want to turn.
Ground_zero298
Ground_zero298
Scs michigan
I’ll go pull the codes up.
Ground_zero298
Ground_zero298
Scs michigan
Okay. Went and pulled the codes. If I start the truck I get the first 4 in the picture.
If I clear them I get the 2 in the second picture.
after tuck is started all 4 come back
Ford Bronco Steering control module failure IMG_8138
Ford Bronco Steering control module failure IMG_8139
Ground_zero298
Ground_zero298
Scs michigan
You need a new clock spring, you broke the ribbon strip that the buttons work off. $120 and you get to pull the airbag!
I’ll give it a go for $120. Thanks man
Ground_zero298
Ground_zero298
Scs michigan
Hit flip up as there are 2-4 different option based on what the steering wheel switches. It's a generic part that fits 2-3 ford vehicles.
How’s the install in that one? Pretty straight forward?
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
@Ground_zero298 its maybe an hour job.
Pull the battery
Drink 2 beers
Ford Bronco Steering control module failure PXL_20221118_011650540
Stick the largest Allen wrench that fits in to release the air bag
Ford Bronco Steering control module failure PXL_20221118_025838107
Unbolt the steering wheel
Ford Bronco Steering control module failure PXL_20221118_025816933
Ford Bronco Steering control module failure PXL_20221118_030443490
Pull a few plastics
Ford Bronco Steering control module failure PXL_20221118_030447616
NORCALGXP
Sacramento, California
2017 Raptor
@Snacktime You should change your handle to BeerTime, you saved the day once again.
Ground_zero298
Ground_zero298
Scs michigan
Pull the battery
Drink 2 beers
Pull a few plastics
No beer. Popping a Valium and having at it. See how it goes.
Ground_zero298
Ground_zero298
Scs michigan
@Snacktime
33 minutes. Fixed it.
We ever meet up I’ll take you for a ride and show you what. 4.5 second 0-60 is like in a 500 horse 2 door.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
@Snacktime
Lol, I am always down for some stupidity! Glad you didn't waste your time like I did thinking it was something inside the steering rack.
