Sporadic 360* camera blackouts possibly fixed
mjp2
2021 Cyber Yellorange Bronco Badlands
I should have taken a photo of the symptom ahead of attempting the fix, but it's this:
Since I've owned the truck the 360* display would randomly show black space instead of a camera image. I'd lose one or more cameras, and they'd eventually start displaying properly again at some future point. It seemed to happen more often after I washed my truck but that seemed an unlikely correlation.
About a week ago I was sitting in the truck with both side cameras not displaying and some time on my hands. I started knocking on the driver's side camera, folding and unfolding the mirror, etc., and that camera's display started working. 10 minutes later my son was done with his appointment and I had him knock around the passenger side mirror housing with the same result. Felt good knowing the issue exists at the camera rather than the expensive image processing module.
Today I took a real look at things and I believe I have this annoying issue sorted. It's simple, basically free, and took about 45 minutes including the time spent figuring out how the mirror housing comes apart.
Tools and supplies: trim removal tool, toothpick, DeoxIT, and dielectric grease.
Take a trim removal tool, fit it into the notch under the outside mirror housing, and work your way around until the whole piece comes loose.
Ford Bronco Sporadic 360* camera blackouts possibly fixed PXL_20250607_212937262
It was a dusty mess in there but I gained access to everything I needed.
Ford Bronco Sporadic 360* camera blackouts possibly fixed PXL_20250607_204818495
This is the connector I was after:
Ford Bronco Sporadic 360* camera blackouts possibly fixed PXL_20250607_204815110
Side note: if your turn signal separates from the mirror housing, it reattaches first from the outer edge under the little tabs and then snaps into place.
Ford Bronco Sporadic 360* camera blackouts possibly fixed PXL_20250607_205349420
Ford Bronco Sporadic 360* camera blackouts possibly fixed PXL_20250607_205430237
The following pics are from the other side of the vehicle. View of the connection itself:
Ford Bronco Sporadic 360* camera blackouts possibly fixed PXL_20250607_205948274
Sprayed with DeoxIT to ensure the contact points were all clean.
Ford Bronco Sporadic 360* camera blackouts possibly fixed PXL_20250607_210017831
Using a toothpick, smear a little dielectric grease into the connector. I had small hands help me out.
Ford Bronco Sporadic 360* camera blackouts possibly fixed PXL_20250607_210216713
Reconnect and test your display before reassembling the mirror housing. If it's working, reassemble and move onto the next.
The connector for the front camera is hidden under the plastic trim piece above the radiator.
Ford Bronco Sporadic 360* camera blackouts possibly fixed PXL_20250607_212319049
Ford Bronco Sporadic 360* camera blackouts possibly fixed PXL_20250607_212119658
Follow the same process, reconnect, test, and put stuff back where it came from.
Results at this point are solid. We'll see how it holds up over time.
Ford Bronco Sporadic 360* camera blackouts possibly fixed PXL_20250607_212705528
Ford Bronco Sporadic 360* camera blackouts possibly fixed PXL_20250607_212719095
Hope this helps someone out there!
Ducati1098
Hopefully it stays working. This is typically caused by a faulty camera though, not the connection.
Had this same thing going on with my front camera until I replaced it. Every time it would go out I would just hit the grille and it would start working again.
Unfortunately Ford sources the most crappy cameras they can possibly find to install on their vehicles.
mjp2
mjp2
Would be a shame if my jostling of everything only moved around flakey stuff within the cameras themselves.
I really hope this does the trick because it's an annoyance that's not sufficiently annoying for me to actually spend money to fix it lol
Ducati1098
Totally understandable. I only replaced mine because it was covered by my ESP and I was the one that replaced it.
So I had to pay my deductible, but also got paid to replace it lol so basically was a wash at the end of the day.
mjp2
mjp2
As others anticipated, this wasn't a permanent fix. Over the past week I had the front camera and the passenger side camera each go black for a bit.
That's a shame. At some point over the next few weeks I'll remove one and see if I can find a loose connection or place where water intrusion might cause intermittent issues.
The search for a free fix continues...
VIRUS
D
Wisconsin
Truck, car, feet
I got this the other day when I got back to my house.
The 360 view showed me going vertical in the gas station parking lot. The other view showed grass and road.
I was parked in my garage at the time. Lol
Hasn't done it since
Ford Bronco Sporadic 360* camera blackouts possibly fixed Screenshot_20250623-121039_Gmail
flip
Phil
IN
www.ruxerparts.com
Fords
Looks like IPMA or APIM had a full blown freak out argument about who's turn it was to make the pics.
