Speedometer recalibration
Spchgexo
Rick
F150 and mustang
I have a 2022 wildtrak and changed tire size to 37”. I tried to change tire circumference in forscan to 2950 but get advance trak error. I just read you can't go over 2800. Anyway to change to get speedometer back
BlueBronco
DFW
Same here. PCM interruption error. AWD relearn worked fine.
Put about 10 miles on it without throwing codes so I am gonna run it as is.
FYI, it wouldn't let me input 2800mm or higher (37" tires = 2950mm) and would keep kept throwing an error when running the AWD relearn. Ended up at 2760mm and was nuts on at 55mph. Will find what it reads at 80mph tomorrow
