Speaker rattle
ForFoxSake
Canada
2022 Ford Bronco Wildtrak
I have a 2022 Bronco Wildtrak (lux package)
Anyone experience speaker rattle from the rear sub and mounted speakers? If so, anyone come up with any remedies? I actually like the sound in this trim level but that rattle is killing me.
NoleDawg
Woodstock, GA
Ford Ranger
Yep, pretty much everyone with lux has that issue, at the very least around the sub. Several threads where folks have polyfilled around the speakers and even pulled panels and laid down dynamat. I haven’t bothered to fix it yet but drives me crazy as well.
ForFoxSake
ForFoxSake
Canada
I can't believe how bad it is for a vehicle that costs this much. They could have dampened it a little bit but didn't bother at all..
ATLBronco75
Tom
Atlanta GA
2.7 Badlands
I stuffed mine with polyfill and then added foam behind the panel where it was rattling.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there, I'd be happy to look into your Bronco speaker concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
ForFoxSake
ForFoxSake
Canada
I'll check this out....did it completely fix your issue?
PMed, thanks.
I'll check this out, appreciate it.
ForFoxSake
ForFoxSake
Canada
I'm going to bring it up to my dealer soon and see if they are willing to help resolve issue
Mjasinski
22 Bronco 4dr, 00 Focus ZX3 JRSC
I just picked up mine on Monday, same issue. I'm so frustrated for how much this cost for something stupid like that too happen. Although at this point I shouldn't expect must less?
edernest
Ed
2022 Bronco Sasquatch
I've had this issue since I've owned my vehicle (Lux package). I reported it to my dealer while performing other warranty work for quality issues and was told they "could not reproduce the problem". Since they could not provide a resolution I removed the side panel in the cargo area to troubleshoot and found that tightening the bolts around the sub enclosure seemed to help for a few weeks but then the rattle returned shortly afterwards.
It will probably bother me enough to try to fix it again (locktite the bolts? rubber washers?) at some point but for now I just think about how badly this was designed every time I drive the Bronco and listen to the stereo. And frankly it sounds bad enough that I wished I had not opted for Lux just so I wouldn't have to deal with it.
ForFoxSake
ForFoxSake
Canada
Mine seems to have gotten worse recently. During my first oil change, I'm going to bring it up with the dealer. It's ridiculous that they couldn't have tested the speakers and ensured there wasn't any rattle before releasing the product.
I'm in the same boat, the lux package regret is pretty high right now.
Karl_in_Chicago
Karl
Chicago
there's a healthy supply of threads over in the electronics/stereo subthread with in-depth discussions and experiences of improving the stock Bronco stereo systems - from base to Lux. Definitely suggest that be your first, second, third and/or more stops.
mrbrenan
Brenan
EL Dorado Hills, CA
2022 Ford Bronco Badlands
I've actually had an issue with the passenger kick-panel speaker rattling. Does anyone else have the kick-panel speaker rattling (passenger or driver)?
Ft. Worth Rob
Ft. Worth
BMW X7, Bronco OBX
I have the base system and installed the kicker key amps and a Kicker sub in B&O sub location with an aftermarket box. Here’s what I did to prevent rattles.
1. adhesive-backed felt over trim pin/clip holes and cloth tape on panel where the pins mount.
2. dynamat on fiat areas of trim panel to add weight
3. Attached quilt batting with double sided tape to back of panel to prevent metal to plastic contact.
Ford Bronco Speaker rattle 1C892F08-6C4F-48F7-B019-B5007C179904
Ford Bronco Speaker rattle A921039B-B2CF-47AC-BD82-232B3F76A157
Ford Bronco Speaker rattle 51F6248B-F521-4511-B683-D59C7AFF33D1
Ford Bronco Speaker rattle 71AECEB5-D3FA-4E31-937C-BE5AF586FD33
