Spare Tire Delete PSA
Acewizard
LUCIAN
Kentucky
2023 Bronco 4 Door 2.7 ecoboost / 2017 Mustang 5.0 GT
I bought the kit and installed only to find out that I have a five-pin rear camera connector which apparantly is a lot larger. I called Turn Offroad and they said that they were working on a new prototype for the correct fit. Well that was a month ago and as of now there is no progress. I was told that I could modify the harness connector to allow clearance. I modified the connector and put the tire delete back on but I still had a half inch gap all around the delete bracket. So I odered Eight 1/2 x 3/8 x 1/2 thick rubber spacers that I attached with the eight bolts around the spare tire delete. I hope this helps anyone that wants to go through the PITA.
Ford Bronco Spare Tire Delete PSA 20240720_161803
Ford Bronco Spare Tire Delete PSA 20240720_161855
Ford Bronco Spare Tire Delete PSA 20240720_161833
TNcoupe
Decatur,TN
2022 Badlands, 2023 BD, 1969 F100, 1955 T Bird
BigMeatsBronco
Allan
2021 FE 2 door
Gotta ask… WHY?
I drove over a drill bit the other day at a jobsite....was able to plug and inflate in less than 10 minutes!!! Far less time than dragging out jack and tools, remove spare, remove flat tire, install spare, install flat tire on tailgate, put jack away....and less work too.
V1Rotate
Brevard, NC
2022 Wildtrak
100% if it’s pluggable I’ll be plugging it. I’d be done and driving away before I even got the spare off for sure. Hopefully it was pluggable..
Your unique case is totally different from an aesthetic perspective.. but his just looks goofy. Nobody asked me though
BigMeatsBronco
Allan
2021 FE 2 door
I agree the removal looks ugly and so do the bandaids.
Felix808
SRV CA
While that is true, there will be times that just pugging a tire isn't going to cover it. If you do a lot of remote trails, I would recommend keeping the spare. It's always that razor rock or tree root you didn't see or account for that takes the sidewall into the realm of un-patchable.
YMMV 🤠
DansDrives
Dan
Snoqualmie, WA
avants.com
2023 Bronco Raptor, 2025 F150 Raptor, 2021 Audi R8 Performance
Thanks for the info. I'm looking for one of these right now and looking at options. Not sure why so many people don't get it; if you crawl a lot and drop on your spare you're in for a really bad time. Rear delete is almost essential for the more extreme angles.
Sunday Money
Ok. Why not just remove the spare when needed, especially when both look equally goofy?
DansDrives
Dan
Snoqualmie, WA
avants.com
Because I primarily use the Bronco for off-road, not on-road. And in the very, very rare circumstances I've had a flat, I'd rather plug it or glue-tread it and be on my way. Takes me 5 mins to plug a flat and far less effort. De-beading is somewhat of a concern I guess, but I've only had it happen once in... 25 years? And even that was totally preventable and my fault.
Sunday Money
My comment was not based on the need for a spare, but rather what looks goofier --- the missing spare, or the delete patch. That said, several options available for the latter.
DansDrives
Dan
Snoqualmie, WA
avants.com
Fair. Without a doubt I think it looks better with the spare, I just don't want to destroy the rear gate, latches, and rear window on Hells Revenge. All the deletes make the rear look kind of incomplete to me.
HeliPilot
Kenny
CT
2022 2.7L SAS
I know this is thinking outside the box, but doesn’t it make just as much sense to simply pull off the spare on those days you’re “Extreme” rock crawling?
