Software Rev Level - how do I check?
NC_Oak
2024 4 door 2.3 sasq
My auto updates were off. Using ford pass, and the interface screen, i see no software release, update date, or revision. How would I know if I have the latest other than turning back on auto updates and letting it sit?
There is an About somewhere on Sync that will show your current revision. There is also an Update Now button that I don’t think requires automatic updates to be enabled.
That said even if that isn’t the latest it doesn’t mean the next update has been queued for you to get it OTA.
FDRS or your dealer can force current updates even if they aren’t queued for OTA
rugedraw
Javier
Miami, FL
2021 Ford F150 Platinum FX4 EB/2023 Bronco Sport Badlands/1991 Mustang 5.0 coupe
Settings > General > About Sync. In there, you will see a Sync version that consists of 5 numbers starting with a 2. Based on what you show there, you can gauge to see where you are.
To see all modules with pending updates, you will need someone with FDRS or full PTS access to check. My FDRS license expired and I chose not to renew it. Otherwise, I would offer to check for you.
