Soft top interior seal coming unglued.
Bronc-Itus
Nick
Orlando Fl
‘18 F250, ‘88 4Runner(sold)
Thank you for posting this. I normally have my Bronco parked under cover, but it's out front this morning in the heat. I just went out and checked. I'm having the beginnings of that happening over the driver's seat. There is enough room for me to stick my fingers between the gap and feel the glue which is tacky, but not super sticky.
I feel like this top is not made for Florida between the utter drenching I get during heavy rain just getting in, and now it's coming apart when it's simply 80 degrees outside. I'm kind of ticked.
I feel like they should replace the top with the Bestop if it is coming unglued with absolutely normal use.
Mine is normally under a carport and my wife takes it to work it sits in full sun. Never been an issue when the ac has been run before parking. Both times this happened I pulled around back first thing around 9 am. Then by noon it dropped. Other times I left the doors open nothing.
Southern Girl
1974 Bronco/2024 Wildtrak
I park outside at work also. Probably most people do. I think we should be able to park outside with the windows up during hot weather without having our top start to fall apart. (What is the correct emoji for this situation?)
Bronc-Itus
Nick
Orlando Fl
Ford Bronco Soft top interior seal coming unglued. 4FF1572F-732A-46D1-AC6C-15F4569095C3
will this work?
Lilj4425
Lilj4425
Jacob
Greenville, SC
2021 Badlands Bronco
Dang...sounds like a bigger issue than I realized. Glad I am not the only one. Wonder if @Ford Motor Company will issue some sort of recall or something for it. I am definitely not paying for a new soft top or glue to fix it out of my own pocket especially with the vehicle still under warranty.
Southern Girl
Please let us know what happens. I'm going to keep an eye on mine for sure.
Lilj4425
Lilj4425
Jacob
Greenville, SC
The Ford person told me over the phone to take it to the dealership and have them put new adhesive on where it’s coming undone. The same person told me this new adhesive is covered under the bumper to bumper warranty I have. I have an appt with the dealership this Friday anyways to get an oil change done so I will see if they can fix it then.
Southern Girl
Good! I stuck mine back together and it is still holding. Next time I will take it to the dealer. Thanks for the update!
North7
North Texas
SUV
Read the fine print, floppy tops are warranted for 90 days or 90 minutes in the sun, whichever comes first.
We're you under the mistaken impression Ford's top design team would give you more?
Lilj4425
Lilj4425
Jacob
Greenville, SC
I just ended up doing it myself. Was worried the dealership would use the same glue from the factory that doesn’t work very well and I would be back at the same situation again in six months. Used Gorilla Glue spray adhesive. Worked perfectly. Take your time if you do go this route though as it is very sticky and dries very quickly. Goo Gone does a good job removing any excess residue also in case you make a mistake.
Lilj4425
Lilj4425
Jacob
Greenville, SC
is this the real ford acct or the one i heard the mods use?
It’s real. I had a case number with them and a person with customer service I was assigned to for this issue.
710-oil-614
Cal
Columbus, Ohio
2023 Maverick Tremor, 2010 Toyota Tacoma
It's real but useless. It's a social media hype account that will recommend you take your Bronco to your dealership for warranty claims.
If you have to pay out of pocket they have a reimbursement pool of money that can assist (but not fully cover) your out of pocket repairs.
That is all the account does.
Chelada
Bulverde, TX
2022 Bronco
That's a shame. I hope the new adhesive works out. I really like the function of the OEM top. Plus I'm not too crazy of the Bestop Slantback look.
710-oil-614
Cal
Columbus, Ohio
LOL it's not made for any weather - just parked in a showroom.
I heard people complain about the water dripping in rain when you open the door and thought people were being nitpicky. It's legit a stream of water that runs inside past the door sil, it's crazy.
Also, that water run downs the door and into the door. I bet the front doors rust inside out.
My soft tops seams are broken in 5+ spots now.
Still waiting for the panels to droop/separate in heat.
