Soft Top Seal Loose on Driver Side
mitruckguy
2022 Bronco, 1941 Dodge WC, 1993 Mazda Miata
@mjrcu have you gotten any solution yet? I’m having the same issue…
OB121
Bay Shore
2019 Expedition 2021 Bronco Outerbanks Sasquatch
My top was closed and the top material on the drivers side folded under the cable a bit and was pinched. This stretched that forward cable which has a spring on the back end protected inside a rubber tube. You can feel that the spring got stretched out and now because of that the top seals loosely above the doors on this side of the Bronco.
This is the part# for the cable/spring assy which is riveted to the frame on the back end of the cable near the spring. Instruction to remove and replace is in the service manual.
Of course as of now the part is on national back order with no time frame for availability.
If I remove the top from the Bronco this summer I probably take this cable out and see what can be done to maybe replace the spring.
M2DZ-7852806-ACable
DillyCrack
Dylan
Philadelphia
2021 Base Bronco
Any fix? I was sitting at a light in 40 mph winds and since then my passenger front is very loose and have a bad whistle coming from it.
@Ford Motor Company
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
@Ford Motor Company
Hi there! Go ahead and send us a private message with your VIN and the name and location of your Ford dealer. I’ll look into this soft top concern for you. Thank you!
