Catmandu
Catmandu
SW Florida
2013 Jeep JKU (Officially Sold), 2015 Expedition
Ok great! Are there any brackets or hardware from the soft top that need removed other than the soft top itself to get the hard top back on? looks to me like the only part might be the brackets up on the roll bar section but those might be able to stay on?
I believe everything can stay on without issue.
skhubbard93
Saratoga NY
'21 Badlands, '01 Z8
Now I wish I had a soft-top prep kit.
Honestly, I'm a bit surprised that Ford took a modular vehicle and made single-purpose components like that side panel that could have been dual-purpose. It's one thing if there's a substantial amount of hardware involved. But it's totally another if it's a panel that simply has a different appearance.
mtap
Mervin
Cape Coral, FL
Toyota Tundra, Hummer H3, Harley Sportster
This was my thought during the swap. Ford did a good job prepping softies to take on the MIC, but not vise versa. Im hoping when purchasing the ST from the factory it will come with all the necessary parts. Like i mentioned before, if purchasing from an individual, make sure it has all the necessary parts you need to convert from MIC to ST.
wtcrabtree
Charleston, WV
Ram 1500, Mazda CX-5
Good to hear that is a pretty easy switch. Everyone complaining about the "soft top prep kit", all of the parts mentioned are easily installed and should come with a soft top when you buy it. The hard top prep kit is wiring and other parts that may never be installed (at least easily) if it didn't come from the factory. Having a dual top TJ prior, all the parts mentioned are not a surprise to me at all.
Bestop_Team
Lux Sponsor (Level 2)
Bestop
Bronco, Jeep
I reached out to bestop and asked if this was in dev. They said no, but the more of us that ask for it,maybe they will do it. I would never take the top off I had a 2 row sunrider
Hi there!
Keep checking our website and sign up for emails to be the first to know about our new products!
- Eryn@Bestop
BroncoDymond88
New Jersey
'23 Bronco
Going to put this here because I didn't know where else to put it lol. The bolts for the brackets above the back seats mounted to the roll bars are part number W721070-S450B
Boonie
Ryan
MI
Just did a roof swap on these two today, thanks to your post it went smooth as butter. Appreciate the write up. Cheers 🍻
Ford Bronco Soft Top <--> Hard Top Swap : Tips & Lessons Learned - UPDATED EC344140-9B72-451C-BA1D-31B7CDDD8944
Ford Bronco Soft Top <--> Hard Top Swap : Tips & Lessons Learned - UPDATED 427D08DC-D592-4866-96FA-183F114136AA
Ford Bronco Soft Top <--> Hard Top Swap : Tips & Lessons Learned - UPDATED A74E1828-0449-4EA2-BE1F-6ED47A1D3111
CTBronco21
CT
Rear Cargo Access Panel Covers:
The final step in the process was to reinstall the rear cargo access panels. When trying to reinstall the panels on the hard top donor, we could not get the panels to fit properly. That is when we noticed the panels are different between the models.
Notice the relief cuts on the bottom covers from the soft top:
The relief area is required for the soft top frame:
Top bracket location (sorry no pic if the bracket itself):
Any chance you have the part numbers for the rear cargo access panel covers with the cutout for the soft top? Also looking for the part number for the top bracket for bolting on the soft top. Thanks, great writeup.
CTBronco21
CT
Rear cargo cover removed on hardtop
Ford Bronco Soft Top <--> Hard Top Swap : Tips & Lessons Learned - UPDATED 15A76F32-C1A9-4BC0-91E7-F0BD1A84492E
Bolts for bracket behind rear cargo cover
Ford Bronco Soft Top <--> Hard Top Swap : Tips & Lessons Learned - UPDATED 48AAABF1-E684-4C17-81B0-52532660EFC2
Bracket for behind rear cargo cover
Ford Bronco Soft Top <--> Hard Top Swap : Tips & Lessons Learned - UPDATED 8D982B58-E5B0-47FC-A0EA-1169447C9F7A
Bracket installed
Ford Bronco Soft Top <--> Hard Top Swap : Tips & Lessons Learned - UPDATED A86C49DE-1DEB-45FE-A836-98FF8AA48CD4
Rear cargo panel with cutout for softtop, Right Side
Ford Bronco Soft Top <--> Hard Top Swap : Tips & Lessons Learned - UPDATED A51D9279-F353-4E8A-AFE4-10FBCCCCC9F7
Cable Guy
Kurt
Audi RS7
But hard toppers don’t get a soft top prep kit — oof
If you bought a soft top it would be easy enough for the kit to include those pieces needed. The Bestop offering does this for example.
Evolkidbell
Northern Colorado
1966 Bronco, 2013 F-150
@Catmandu great write up.
Any chance you might have taken a note of the PNs for the soft top side panels?
Ford Bronco Soft Top <--> Hard Top Swap : Tips & Lessons Learned - UPDATED 2693814F-1F4D-4DFF-A994-C28328DB1690
Catmandu
Catmandu
SW Florida
thatsmydad
Ohio
2022 Bronco, 2016 F150
