Soft top care and maintenance?
unfortunate
NA
Never owned anything soft top before. What kind of maintenance if any is required or recommended to extend the life of the top? What’s the expected life?
Jmet8
James
South
Toyota
Hi. Lay windows flat when out never roll them up. I used a harbor freight moving blanket as a pouch and put a layer in between each window. This will help from getting any kind of scratches or rubber marks on the window part which will then not come off. Wash them with the hose to get most of the debris off the windows then only use a mild detergent like Dawn really nice microfiber towel. As for the top chemical guys makes a
Protector and wash for the top. A little extra work to help keep the windows looking good for a long time.
Dillhole
Andy
Van down by the river
2012 Jeep Wrangler 2dr
I've had a soft top Jeep for going on 10 years and had 3 different tops on it. The factory one, traded someone my factory for a Trektop that top ended up being garbage and bought the different Trektop I have now that is about 5 years old.
I see you're in Arkansas but I'll just blanket statement this for whoever reads it.
Don't scrape snow or ice off in the winter, could crack them. Seriously in the winter just don't touch them. Like use the weight of the brush at most to get snow off but that's about it. Get used to using your mirrors until the back window melts up. Hopefully Ford put some afterburner heaters in these things like Jeep does.
Don't try to remove the windows in the winter, could crack them
Don't rub them when they are dry it will put swirls in them. If you want to clean them either do it when you're washing the vehicle or use a wet towel.
Back in the day we'd lube up the zippers in the fall so they'd still work smooth in the spring but I believe these new ones are zipper free, mine now only has zippers on the sides of the rear window.
That's all I do with mine, it still looks and operates like new and could easily see getting another 5+ years out of it. I run it all year long even through our harsh 120" snow winters.
Southern Girl
1974 Bronco/2024 Wildtrak
Can someone recommend a good soft top window cleaner?
Catmandu
SW Florida
2013 Jeep JKU (Officially Sold), 2015 Expedition
Roundabout
Just be sure to NOT use a glass cleaner, had someone at work ruin a couple vehicle windows.
We use Zep Vinyl Window Cleaner but I'm sure any product marked for vinyl and plastic will work.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Learned some stuff here. Thanks!
I’ve been using Invisible Glass wipes w/o an issue. But, I guess I’ll switch over. My father in law works on boat upholstery and suggested something…I’ll get the name.
I bought a bottle of Blue Magic, but haven’t used it yet because I was advised to not put anything on it if I plan on ceramic. Also noticed 303 makes one and I like their products….
I’m planning on ceramic coat in the coming weeks.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Anyone on this forum who doesn’t have their Bronco yet - We typically lick the windows of Bronco’s as we see them; helps clean them at the same time. @Tricky Dick knows what I’m talkin’ about…
Southern Girl
Mine are really dirty. :LOL:
11MrQuinn11
Belle River, Ontario, Canada
2018 F150/ 2021 Bronco Big Bend (non-Sas) 2.3L man
Any suggestions for the best soft top conditioner? Best practices/methods? (First time soft top owner here)
865Bronco
Robert
Knoxville
AMB Badsquatch, Land Rover LR3, Ford F-150
I bought a two pack of the Chemical guys convertible cleaner/protectant to put on mine.
Let us know if you like it. I’ve used Chemical Guys for other things but this will be our first soft top so there will be a definite learning curve.
Bled656
Daniel
Phoenix Az
2018 f150 ecoboost
Has anyone here used a ceramic coating or something similar? Never have had soft tops before, and is there any tint you can put on vinyl? I live in Phoenix, Az and heat here is brutal
