Soft top broken tabs
LT. DAN ICE CREAM!!!
Philadelphia, PA
2021 Badlands
So how excatly did that work, I'm confused on how to attach the wire? Sorry if it's obvious lol
Basically just drilled very carefully with a Dremel on the red marks and ran some wire through the plastic on the cloth side, then fed the wire through the plastic side and twisted it tight.
Ford Bronco Soft top broken tabs 1640812338301
Lexo52
Arlexis
Ford F150
Oooh I see. That makes a lot of sense. I had t really messed with because I didn't want to make it worse! But will need to do this. No leaking through the tab holes?
Philadelphia, PA
2021 Badlands
So long as you don't drill through the cloth, there should be no leaks because the repair is under the cloth.
BigJack
Jack
Pittsburgh
Jeep Patriot
This just happened to me yesterday. I wasn't even trying to take the top off. I noticed it when i got out of the car. I think it may have happened when i propped up the top to put something in the trunk. Maybe when i put it back down. I'm taking it to the dealer Tues.
HorizonHunter
Joseph
Chapel Hill, NC
Grand Cherokee Trailhawk
Anyone had this resolved under warranty?
Took delivery of mine Saturday. Went to take the top down Sunday. Local dealer said they'll get me in for service appointment to look on Thursday. I've been terrified to actually attempt taking the top off to investigate and make it worse.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hey, BigJack! I would like to look into this broken top issue you're experiencing with your Bronco. Could you please send over a private message with your VIN and the name/location of your local Ford dealer?
BigJack
Jack
Pittsburgh
Jeep Patriot
Yes. Thank you. Sending you a message now.
flip
Phil
IN
www.ruxerparts.com
Fords
TECHNICAL SERVICE BULLETIN
Soft Top Roof - Loose Exterior Fabric On Rear Window
22-2055
21 February 2022​
Model:
2021-2022 Bronco
Soft top roof
Issue: Some 2021-2022 Bronco vehicles equipped with a soft top roof may exhibit loose exterior fabric on the rear window assembly. This may be due to broken D-pillar clips on the rear window. To correct the condition, follow the Service Procedure to replace the D-pillar clips with rivets.
Action: Follow the Service Procedure to repair vehicles that meet all of the following criteria:
• 2021-2022 Bronco
• Equipped with a soft-top roof
• Loose exterior fabric on the rear window due to broken D-pillar clips
Bryanm
Raytown Mo.
2021 Ford Bronco big bend/2022 Badlands
Rear Driver side on soft top…broke my plastic tabs. Suggestions? I searched back to March.
Mine is going in Wednesday to be repaired under warranty, also good looking danes! I only have one riding in mine
Ford Bronco Soft top broken tabs B4002A18-7E51-40CE-8C45-07E89611261C
Ford Bronco Soft top broken tabs D1F64C21-E1E6-4B60-B6EC-2A2ED3F9F9C8
Ford Bronco Soft top broken tabs 5D661AF7-A020-4951-A16D-65E41FBB81E4
Ford Bronco Soft top broken tabs 5EC97985-B100-4CF0-9187-1412286EC06D
Ford Bronco Soft top broken tabs 9B8A8656-F1A8-447D-BCE2-CA7A80CFE5F8
Ford Bronco Soft top broken tabs E7725392-A444-48A4-A03D-5EB342F2DA04
Ford Bronco Soft top broken tabs 2C104C27-39FB-4009-92A8-57D1BB51C71E
Mine did the same thing. It is going in Wednesday to be repaired under warranty. But I did repair it with some two part epoxy at the tab locations until the dealership got the parts in and has held up for several months with no issues, glad to see I'm not the only one with a Dane riding shotgun!
Ford Bronco Soft top broken tabs 20220209_161239
stbanning
sean
Bonney Lake
f150 platinum, mazdaspeed miata
from what i undestand is the tsb fix its to pop rivit them together
Jacksonholio
2000 Tahoe Z71
Yes I had my rear soft top panel replaced under warranty for this.
Headsong
Hoping they move to metal soon...
kevin.gt
Kevin
Canton, GA
Yeah they should not be fastened with cheap thin plastic tabs that break if the user grabs from the wrong area.
With the TSB and warranty replacements, seems like Ford agrees. Bookmarking this TSB and thread just in case.
my rear isn’t broken, but holy crap the side windows were crazy tight to stretch into place on my week old ā€˜22. Took me over an hour of working them and I’m still afraid I have too much tension to the seam. We’ll see.
