Socket stuck in door - how to retrieve?!
rabinaba
New York
2026 Ford Bronco Big Bend Sasquatch
I’m in the process of wrapping my Bronco and I took the door handle off to make things easier. When putting the handle back on, I had a socket on an extension in the access hole. In the process, I pulled the socket out too quickly and it popped right off into the door.
I have no idea how I’m supposed to get this thing out now. Is there another way to access that side of the door? Will taking the door panel off help? Any suggestions?
Jakob1972
Everglades
Steven
Spring Branch, TX
2025 Trax 2RS, 2022 Camaro, 2022 Silverado, 2004 Fummins F250, 2008 Chevy Cobalt
Everglades
Let me guess it is a 10 mm. I always start any project with a hand full of 10mm sockets tossed into the work area as a sacrifice to the tool gods.:crackup:
Actually if you take off the door panel you should have access to the area. You can use one of those magnets that telescopes out.
HBTFD 2.0
HBTFD
Georgia
24 F250 Tremor
You can take the door panel off and easily get to the socket. YouTube the process. The plastic clips are prone to break so be gentle removing.
rabinaba
rabinaba
New York
It was actually two 5 mm sockets, so that basically adds up to a 10 mm.
Taking off the door panel worked surprisingly easily. Now if I could only figure out why I can’t get this door handle back on!
B-Dog15
Brandon
Covington, Ky
2025 Base 4-Door
Did you try and put the two 5mm sockets back in the door?
GL4DY5
Everglades
Liam
Planet Earth
2024 Ford Bronco
Everglades
I just solved a similar issue with a long flexible claw tool made for these types of problems.
I had this:
Ford Bronco Socket stuck in door - how to retrieve?! IMG_8094
Stuck in here:
Ford Bronco Socket stuck in door - how to retrieve?! IMG_8096
ever since I bought the Bronco. Most times I turn it would rattle and slide back and forth along the inside of that cross member. I finally found where the noise was coming from and got it out with this :
Ford Bronco Socket stuck in door - how to retrieve?! IMG_8097
I tried magnets, sticky tape and they didn’t work. I used a pick and my finger to get it into position then pulled it out like an arcade claw machine.
Jakob1972
Everglades
Steven
Spring Branch, TX
Everglades
I should make it clear that taking the door panel off worked and I was able to get the door handle back on. Only a few more panels to go!
Glad that worked.
Looks good too
rabinaba
rabinaba
New York
The hood has a good bit of debris underneath and I’ll probably have to redo the tailgate with the hinges off…but all in all, I don’t think it’s all that bad for my first attempt.
CalvinT
Calvin
Phoenix, AZ
Glad taking the door off worked for you.
The door and frame are aluminum. The socket is steel.
Next time try a magnetic on a string before you have to take the door off.
