Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Current Bronco is a 2022 4 Door Black Diamond 2.3 Auto with no other options! That's right no MID package sensors or doohickeys.
Ford Bronco Snacktime's Broken Bronco Build 1701112013283
Current Bronco Mod List with fancy links!​
Steering​
HOSS 3.0 steering rack JKS Tie Rod Braces Link to my failure​
Swapped out at 5k miles BroncBuster HOSS 3.0 Driver Bushing
Icon Tie Rods
Dorman Tie Rods​
Bumpers/Tailgate​
Front is DV8 OE Plus with a harbor freight 12,000 winch custom installed​
Hammer Built Tailgate Reinforcement​
Skids​
Factory rock sliders with 2x2" square tubing steps
ARB rock sliders bending slowly lol​
Suspension​
4wp coilovers​
Front set at 4" of lift​
4wp/pro comp control arms @15K miles​
Rear set a 2" of lift​
200lb springs installed​
Rear shocks mount moved up 2.25"​
Core4x4 lower arms, Cruise series​
Other stuff​
1/2" Differential Drop​
1/2" Body lift​
KMC 542 17x8.5 with 18mm offset​
37x 12.5R17 patagoochies @24k​
35x12.5R17 Kelly MT​
Form Headlights​
Current issues​
Exhaust?​
Regear?​
Dates, not with my wife​
10/31/22 - HOSS 1.0 Steering rack 2500 Miles​
4/8/23 - Passenger CV Axle MB3Z-3A428-B MB3Z-3A428-Q​
7/30/23 - Passenger cv axle seal replaced MB3Z-4B416-A​
7/30/2023 Replace inner race on M190 cv axle passenger side(stole from parts collection)​
8/16/2023 Ordered M210 CV Axles​
10/29/2023 Killed a taillight​
11/20/2023 RIP M190 @9200ish Miles​
11/24/2023 Ordered M210 w4.46 gears M-3002-446BF​
12/6/2023 New ARB sliders​
12/16/2023 Killed a drivers side Icon tie rod 10500 Miles​
1/1/2024 Form Headlights​
2/27/2024 Passenger side Icon tie rod clunking 12,938 Miles​
7/14/2024 Replace lower control arms​
8/24/2024 Form Headlights faulted out​
5/10/2025 Drivers Dorman inner died at 20,000 Miles​
5/12/2025 Killed a Icon inner tie rod at 20,500 Miles​
7/6/2025 Passenger inner Rough Country tie rod 22,500 miles​
5/17/2026 Passenger side inner Rough Country developed play 27,000miles​
6/21/2026 Replace passenger side tie rod.​
Highlight reels​
Prairie City Gold Country Broncos I am at the very end of the video​
Snacktime
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
I figure I might as post my build since I need to keep track of everything.
April 2022 I bought a Big Bend with a bunch of odd options off the lot! 2.3 with 3.73 gears!
Ford Bronco Snacktime's Broken Bronco Build PXL_20220326_192333223
Like a good car person I took it apart.
Ford Bronco Snacktime's Broken Bronco Build PXL_20220326_201801377
Zone 2" lift!
Ford Bronco Snacktime's Broken Bronco Build PXL_20220326_232215710
Then some wheels and tire @ 200 miles...
Ford Bronco Snacktime's Broken Bronco Build PXL_20220402_165751817
First time in the Dirt at 500 Miles, Wild Horses advent. With my modified rock rails.
Ford Bronco Snacktime's Broken Bronco Build PXL_20220501_180456905
Virgin Metalcloak skids, look at the front end drop!
Ford Bronco Snacktime's Broken Bronco Build PXL_20220604_150851911.MP
Ran Moonlight Madness down with Clovis Independent down south.
Ford Bronco Snacktime's Broken Bronco Build PXL_20220625_231736724
Ford Bronco Snacktime's Broken Bronco Build PXL_20220626_030338560
Ran signal peak with some of B6G Members
Ford Bronco Snacktime's Broken Bronco Build PXL_20220716_201605845
Then out of nowhere my bronco turned green! My ordered Black Diamond came in with another 2.3 and automatic transmission.
Ford Bronco Snacktime's Broken Bronco Build PXL_20220917_182832976
Friday at home
Ford Bronco Snacktime's Broken Bronco Build PXL_20220918_000423300
Saturday
Ford Bronco Snacktime's Broken Bronco Build PXL_20220918_164656114
Ford Bronco Snacktime's Broken Bronco Build PXL_20220919_155835623
Sunday!
Ford Bronco Snacktime's Broken Bronco Build PXL_20220924_220612964
Following weekend with Nevada Bronco Club out of Reno
Ford Bronco Snacktime's Broken Bronco Build PXL_20221001_205858492
Ford Bronco Snacktime's Broken Bronco Build PXL_20221001_205908592
Poof a hard top that I stole off my Big Bend!
Ford Bronco Snacktime's Broken Bronco Build PXL_20221004_182156755
1/2" body lift to clear my light bar.
Ford Bronco Snacktime's Broken Bronco Build PXL_20221004_225608819
Some mall crawling on dirt roads...
Ford Bronco Snacktime's Broken Bronco Build 1ap2TmjpCrOMglk-IN0HqsOFg=w822-h1096-no?authuser=0
https://photos.google.com/photo/AF1QipM1IW7PlsngkdevKVMYSqnirhHopDIq5XYVPQkz
Went out to the Rubicon with some other Bronco's
Ford Bronco Snacktime's Broken Bronco Build b-0prUYkaKAkSY3TPHNziQ46u=w1481-h834-no?authuser=0
Snacktime
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Blew my steering rack after I aired back up my tires and hitting a 6" rock.
Ford Bronco Snacktime's Broken Bronco Build LY3fOEGv5zlOfT2A2hqtho_dQ=w1481-h834-no?authuser=0
Video
https://photos.app.goo.gl/CMzEyoJ4aciiHAc49
Take up adjuster missing?
Ford Bronco Snacktime's Broken Bronco Build hf2JF8uGRcbPFDlWNNgexuNnY=w1481-h834-no?authuser=0
Ford Bronco Snacktime's Broken Bronco Build 4afaiG23-HdV7FT9GHc09SYuW=w617-h1096-no?authuser=0
Programing
Ford Bronco Snacktime's Broken Bronco Build BSyAIAFKkUJrcxd_gaiZ8aRic=w1481-h834-no?authuser=0
Fixing the clock spring, look an air bag!
Ford Bronco Snacktime's Broken Bronco Build zj2ajUt2EkXKw8kNfRufEtHih=w617-h1096-no?authuser=0
Ford Bronco Snacktime's Broken Bronco Build 8uUlLsxxVr-iZoOsPSmDIEfj3=w617-h1096-no?authuser=0
Cutting my Christmas tree!
Went to Praire City to Play with Gold Country Broncos
Ford Bronco Snacktime's Broken Bronco Build _pbtI-PXLlj3zyA-IAxbK_vWh=w1481-h834-no?authuser=0
Ford Bronco Snacktime's Broken Bronco Build QjY1yS8sSBJKAZ1erA5dLQe5C=w1070-h714-no?authuser=0
Bent my slides...
Ford Bronco Snacktime's Broken Bronco Build wF_6zY8zHtlPYCNbqGbbUff6E=w1481-h834-no?authuser=0
Went snow wheeling with Gold Country Broncos (not the time people got left behind).
Ford Bronco Snacktime's Broken Bronco Build 9YqsiF4J2X95YRGsZ-tofI-_w=w1481-h834-no?authuser=0
Went snow wheeling again and had way to much fun.
Ford Bronco Snacktime's Broken Bronco Build 9Ffu-Dyancqci3o3S2YhM1-Fg=w1481-h834-no?authuser=0
Installed Trick-Flate onboard air system.
Ford Bronco Snacktime's Broken Bronco Build hqcNn4wNi0vBeLifVUqw_IzIw=w617-h1096-no?authuser=0
Went extreme snow wheeling and had even more fun.
Ford Bronco Snacktime's Broken Bronco Build -MwPEvluWvIAp-B62p7DQfN0Q=w1481-h834-no?authuser=0
Ford Bronco Snacktime's Broken Bronco Build 737sYLU2LOsDEK9e4v6RX9h2A=w1481-h834-no?authuser=0
Poof we have 37s
Ford Bronco Snacktime's Broken Bronco Build a-qLeVlLDxy5nbEaKABDwR_ng=w1481-h834-no?authuser=0
Hard core upgrades required to run 37s! Damn tire shop lost most my valve stem covers.
Ford Bronco Snacktime's Broken Bronco Build PMHsLjq1t47bNkIsLdWyodVAQ=w617-h1096-no?authuser=0
SS Bronco
Shayne
Loomis CA
2021 Bronco , F600, F5, LJ20
Can’t wait to see what’s next.
da_jokker
Jeep Wrangler JKUR
I was going to say, I have a front bumper off my WT that you can have, but looks like you might add the capable bumper now?
Snacktime
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
I need full armor but I bought bigger tires lol
Zhang
Gavin
Pittsburgh
How's the cv joint on your BB? Little worrying about putting a 35 on m190
kodiakisland
Arkansas
What was the deal with the clock spring? Did you have to change it out when adding the 3.0 steering or something else?
Snacktime
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Hammered on my M190 yesterday with my 37s and still not had any issues going on 5-6 trail runs(real trails).
When my steering rack failed I lost center, if you over rotate the steering wheel you break the wiring for the switches on the steering wheel. Pretty much junked my clock spring when it failed trying to drive the Bronco last couple hundred feet to the parking lot.
Snacktime
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Capable bumper is awesome but the plastic covers are crap...
Ford Bronco Snacktime's Broken Bronco Build karr_Kwk8B3S-qfY3E-BXCuWQ=w1465-h825-no?authuser=0
Since it was $40 a cover I just jumped on the Westin XTS Bumper deal on Amazon. So time to dig out my winch! Presenting the 12,000lb Badlands that has never done anything but load my old 74 jeep on a trailer a few time. its more sun baked than used lol. Actual had to pull it during the summers as it blocked off the radiator to much. Thinking it might choke the bronco down a bit but we will see.
Ford Bronco Snacktime's Broken Bronco Build D9OrIyPFz1Q5SD7Q2EYPfgWEg=w612-h1088-no?authuser=0
NORCALGXP
Sacramento, California
2017 Raptor
Valhalla
Valhalla
Chattanooga Tn
Nice build!
This seems to be one of the more common rack failures any tips for a guy planning on doing the Hoss 3.0 rack?
