Slow Coolant Leak
jas129
TX
2022 Bronco Badlands
I've searched, but not found any answers. I have a March 2022 delivered 2.7 Badlands with 10,000 miles. I seem to have developed a small coolant leak and would like to know if anyone else has run across this and what the fix ultimately was. I have seen a couple of threads from others, but the two which indicated similar issues did not report back a fix.
I smell a slight coolant odor after driving for awhile with the engine fully warmed up. I do not ever see any coolant on the ground and I have not been able to find any signs of a leak at hose connections, overflow tank, radiator, etc. I have added about 1/2 quart three times since new to bring the level to cold min. Oil level is not rising and is not milky. I have not noticed any type of exhaust odor indicating it is burning it.
This is not the issue where the pully hits the coolant hose. Mine was produced after that and has a clip installed to keep the hose away from the pully.
flip
Phil
IN
www.ruxerparts.com
Fords
Are you noticing any drops of coolant on the ground? Hate to speculate but on something this I'd be looking at a hose clamp and an accumulation of white crusty buildup around a connection. If it can't be located visually, it's going to need to be pressure tested and checked. Next best thing is to have the dealer put some UV dye in the system, drive it for a few weeks and have them check with a black light. If it's not an external leak, not running bad or missing first thing on start up, not showing up in the oil pan or transmission fluid, it could be going out of the exhaust through a turbo.
da_jokker
Jeep Wrangler JKUR
Check your reservoir cap as well. Wranglers are know to actually have coolant evaporate some strickly because of heat via the reservoir cap that is loosly snapped on (and not sealed very good).
jas129
TX
Thank you for the replies.
I do not see any coolant on the ground and I have not been able to see traces of it around connections, clamps, etc. The reservoir cap is on tight and does not appear to be leaking.
I do not smell any coolant from the exhaust. I do smell it from the front of the Bronco after pulling into the garage. I feel that it is an external leak because of this and it should show up somewhere. I'll keep looking. I'm trying to avoid the dealer, if possible. I'll keep looking.
Slater
Just Slater
Maryland
Soul crushing Camry now cancled out by Badlands
I’m glad I found your thread. I just noticed this issue on my late March 2022 2.7 with just under 7,000 miles. I pulled into the garage last night, and swore I smelled coolant for just a second at the very front of the car. I looked crazy intensely sniffing all around the grill. Checked under it later in the evening and this morning. Checked under the hood and I don’t see any leaks. I’ll go check the oil too and the exhaust too. No issues on power or general performance. Seems to operate completely normal.
Watching the thread and will report back if I discover anything new.
jehines3
Easton, MD
Lexus RX350L, Chevrolet Silverado, Lincoln MKC
Both of you indicate smelling coolant, but not whether you have had to add coolant. What is the level?
Prew
Randy
Fenton
2011 F150
Check for a leak both cold and hot, may be leaking on a cold engine. When the engine warms up, the coolant evaporates with the heat and then you smell it. (20 years as Ford Technician).
jas129
TX
I have added about 1/2 qt three times in 10,000 miles. I am sure the coolant is leaking when hot and evaporating off something hot. I’m just not sure where the leak is.
RagnarKon
Ford Bronco, Escape, Focus
Personally I’d unbolt the bash plates and see if there is any sign of coolant pooling on them.
If you don’t… and there is no other visual sign that you can find… then I agree with @flip—probably should have it pressure tested to confirm the leak. Most people don’t have the means to do that in their own garage… so it’ll probably be a trip to the dealer.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there. This leaking concern doesn’t sound like something we want you to experience with your Bronco. Could you please send us a PM with your VIN and the name and location of your Ford dealer? I'd be happy to look into how I can assist you on my end.
SirBenimen
Ben
2021Bronco 2020 GT500 2016 F-150
Just discovered I’m leaking coolant as well. I have an appointment scheduled for oct 31st. I searched from the top and bottom and can not pinpoint it but it’s right around the seal between the engine and transmission. Not sure if it’s leaking from there or leaking from the top and running down that joint.
0ne
Nate
CO
Flex
I’m not smelling or seeing coolant🤞but I had to add coolant, maybe half a quart in total, a couple times during the first 1000 miles that I attributed to air in the system from the brand new assembly.
MayhemMike
Mercury
I once owned an 1989 Ranger 4x4 with a six cylinder that started losing coolant. No signs of a leak and no issues in the motor oil. Tests conducted did not determine where the coolant was going. Dealership decided to change out the heads. Turned out there were hair line cracks in the heads after 50K miles. Ford replaced the heads under warranty, and the problem was solved.
lifeb4work
Pueblo West, CO
2022 Bronco Badsquatch, 87 Suzuki Samurai.
I've noticed this with our Bronco with the 2.7 as well. Built-in February of this year.
