Slide out tailgate install - '21 BL Sas
Wanderexplore
Andrew
Boulder, co
Lancer gts
I've been wanting this since day one. I have a kitchen setup with a jet fuel fuel burner that takes up the tailgate table, so perfect to have for cooking. I do astrophotography/landscape/drone photography, so great to have extra space out the back. I lose a little vertical space but have more space organized underneath just for emergency gear. Took me about an hour, only needed a 10 & 13mm rachet.
Ford Bronco Slide out tailgate install - '21 BL Sas 20230128_130356
Pull these latches from the front and try not to break rear tabs.
Ford Bronco Slide out tailgate install - '21 BL Sas 20230128_130738
Ford Bronco Slide out tailgate install - '21 BL Sas 20230128_131956
Remove the floor
Ford Bronco Slide out tailgate install - '21 BL Sas 20230128_132405
Easily pops off
Ford Bronco Slide out tailgate install - '21 BL Sas 20230128_132837
Use the included covers over the holes
Ford Bronco Slide out tailgate install - '21 BL Sas 20230128_132849
I guess just shove this in there?
Ford Bronco Slide out tailgate install - '21 BL Sas 20230128_133435
See that bolt with the wide washer? That's the wrong one. Use the 2 narrower headed bolts here so you don't have to take it apart and redo it.
Ford Bronco Slide out tailgate install - '21 BL Sas 20230128_134750
Using the correct bolt, screw down the tailgate here.
Ford Bronco Slide out tailgate install - '21 BL Sas 20230128_140445
Push the bolt through the cover. Align before fully tightening all bolts.
Ford Bronco Slide out tailgate install - '21 BL Sas 20230128_140949
Top just pops into place. Slideout is smooth and clears table.
Ford Bronco Slide out tailgate install - '21 BL Sas 20230128_141020
Success
Ford Bronco Slide out tailgate install - '21 BL Sas 20230128_141200
I keep a bungie here to hold the lid to my fridge. Perfect for this.
Ford Bronco Slide out tailgate install - '21 BL Sas 20230128_141721
No clearance issues with the jcr off-road fold down table, flush with rear seats, and shiny. Just a reminder that hitting your hand when it's cold out hurts 8000x more.
5280Bronco
Denver
Looks great! It also looks like it would clear the rear door if it's just in the 90 degree position right? Or does it have to be in the fully extended position?
‘21OBX
90Bronco19
2022 bronco outer banks
I’ve been wanting one of these since it was announced. Very nice! I’ll be keeping an eye out for someone selling used. I missed out on one this week for a great price.
JJ Bronco
Justin
Columbus Ohio
Lexus RX
Question for you, can you sit comfortably on the tailgate with soft top up and when it's down?
I've wanted this since the first saw it.
  • Like
Reactions: R11
Migs1313
mark
Illinois
Bronco & Explorer
Have you tried putting the doors in back yet with it installed?
Wanderexplore
Andrew
Boulder, co
Lancer gts
It's - 2° so won't really know for a bit, but fine with top propped up so far.
Who iz
Otis
End of the Oregon trail
F250, 4Runner, Jimmy
No, don't plan on it anytime soon. Usually have the back full.
Thank you for doing the cold weather install! Great images !!!
I just received mine and can't wait to install it on a dry day off. How about one more image -with the slide out only a foot (or half way) and the new floor down in place please...Want to see the new almost level floor created after your installation now.
edit...Skip my image request...finally installed it!
Who iz
Otis
I've wanted this since the first saw it, before I had the Bronco.
Rain rarely stops here this time of year... Have been hoping for a clear day off work/finally gave up waiting for blue skies in western Oregon and just installed it in the rain.
Install is stupid easy- just don't look at the useless instructions and you will know what to do!
*Yes, with the soft top down you can sit on the slide out... and even rest your shoulders on the soft top. Even better to have the:
IAG Performance V2 EZ-Lift Soft Top Assist System for 2021 + Ford Bronco 4 Door Soft Top
and enjoy the party with your tailgate table of choice too!
Vern
Datsun 280z
Can you post a photo of yours installed?
