GToddC5
Todd
South Jersey
www.bronco6g.com
I have lots of mods, but the most entertaining by far is the Oracle light up letters. I've seen a couple others since doing mine, such as BTRCUP and MAEPRL - hoping to see more in the future!
Ford Bronco Single best modification you've made on your Bronco!? 1683118974475
kevin.gt
Kevin
Canton, GA
Thanks. I will definitely be looking into ordering the set for my Wildtrak! Did you recover to match your existing cloth seats, or kept it leather covered?
I kept them leather and like the look just fine. I think the covers could be swapped but can’t say 100% because there is a little bit of a slit in the leather headrest covers to account for adjustable angle. Flip’s follow up posts to this question lists the options
Squatch
For me, it was my modified skook:
Ford Bronco Single best modification you've made on your Bronco!? 20230327_092600
Ford performance tune and Pedal Commander on my 2.3 7mt completely transformed it. It’s very peppy now and I can actually pass cars in 6th gear on the highway😀
Have you tried downshifting? j/k ;) I find a lot of people don't rev this engine high enough... it would help if we had a useful and easily read-at-speed tachometer. That said, I'll be adding the tune. Which order did you add the tune and pedal cmdr? Could you tell the difference that the pedal cmdr made?
Arokcrwlr
Kraig
US - Alabama
2014 F150, 2014 Focus, 1973 Bronco
If you have a lift and bigger tires - Rock Slide Engineering step sliders. They are expensive, but a game changer for getting in/out and they are plenty stout especially with the optional skids.
Brian514
Brian514
2022 Ford Bronco Badlands
I haven't done much, but honestly good floor mats on drivers/passengers side are an absolute must. I'm in sandy/dirt lots a lot and they are so easy to clean.
For sures! I got the OEM mats with my Ford points.
Brian514
Brian514
No other changes just put a new clean oem air filter in and oem exhaust. Did it myself in about 15 minutes. Purchased it with discount at Lethal. Ford states that an ASE mechanic has to do it for warranty. I think they would have a hard time proving in court that the only tune available that you can download and install makes any difference based on who pushes the button. Also you save your stock tune so always can go back...not sure why but maybe if you mess up some how. Also exhaust sounds better with tune! I was going to get an aftermarket cold air but not sure it would do any better. It is so good now.
Nice! I’m sold! Where did you purchase the Ford Performance Tune? I want to look into making the purchase.
1st 75th ranger
jeffrey
nj
What is the best modification that you have made to your Bronco that you think others would also enjoy? For me it is easy, I added 6.5 inch back speakers. SSV Works has a rear pod replacement that converts the rear speakers to 6.5 inch Kicker speakers. I then added 4 inch Kicker speakers to the front dashboard. This has greatly improved the sound quality. Also, it was a super easy install, since they are plug and play on the rear speaker pod swap.
bronco buster front tie rod up grade
front tinted windows
water proof home made back deck cover
co axle alpines deck pods ..alpine 6 in kickers down low
mti sub box on tailgate with kicker 10 with 5 channel amp and processor
blow off valve for the woosh and black letters on front grill
sas so just bigger tire later when i can afford like "full size" 35 ss-m16s lol
Brian514
Brian514
IAG soft top struts. Should have come from the factory with struts on the soft top. The little prop bar is ghetto.
Yes! I also added the IAG soft top struts. Makes it so much easier to get stuff in and out. I also installed hood struts.
tourproto
Portland, OR
2004 BMW 330i, 2022 Bronco BL 4DR
Go Lakers! The Broncos should come with the tune installed with the extra power and much smoother Trans shifts and more low end power...but they are set for 87 octane and ok specs for the masses (cant require premium from the factory or most people would lose their minds). Spend $5-$7 more a fill up for premium gas and install the tune and it becomes a different machine and you will wonder how you lived without it!
What did it do to your gas mileage? I know owning a Bronco isn't about MPG, but I am already at 17mpg with the manual. If I add lots of horsepower and pay $3-5 more per fill-up but also go from 17mpg to 14mpg, the "smiles per mile" won't offset the decreased range (for me, YMMV).
D&O
Derek
Seattle, WA
www.youtube.com
2023 Bronco / 2021 F150 / 1965 Mustang
Ford Performance Tune. It's is like taking a GT Mustang and making it a GT500 Shelby. Upset I wasted 9k miles of avg 2.7l Bronco driving before installing in 15 minutes.
I agree, I got the tune for the 2.7 recently and it made a significant difference. Huge improvement in drivability. It accelerates more smoothly, has more low end power, and it shifts far better. It also calibrated my speedo to the new tire size (33" upgraded to 35"). It's hard to say how much the tune vs. the correct speedo change effected the MPGs, but I am getting 3 MPGs better now compared to before the tune. I was already running premium fuel in it, so that aspect didn't bother me.
Billy Goat
Pete
Fort Worth
2022 Bronco Velociraptor 400
That's really cool. I'm digging the name. Add the performance tune and your flaming hot
GToddC5
Todd
South Jersey
www.bronco6g.com
I considered it, but I've been using a Sprint Booster for some time now and it really scoots when I want it to. Takes away all the throttle lag and puts the power down much quicker when you want it to.
D&O
Derek
Seattle, WA
www.youtube.com
Mine is actually getting better MPGs with the tune. Now that the speedo is correct to the larger tire size, I am getting 17.6 MPGs out of the 2.7. That is better than before when I had the stock 33" tires on it. Only downside is the need to run premium fuel, but I was already doing that. I will carry a can of race-gas with me just incase I am at a fuel stop that does not have premium.
