Signature vs standard lights ?
Rydfree
Benny
Alabama
Consumes less power? Okay, sure LED can consume less power, but by what, a few watts.
I'll counter with the incandescent bulbs will last years and will cost $1.00 to replace. If the LED circuit goes tits up, bring your credit card rather than pocket change.
But they are cool...
I've never had an issue with a factory LED burn out and they do consume far less power . Much easier to see in fog or if bright sunlight is on them also so there is a safety factor.
On another note the prices have came down considerably as more people are switching over to LED . In my older house I switched out all the bulbs for LED and what totaled 1900 wats now is 99 watts . I don't really care if they leave every light in the house on now......but I'm still like my old man and find myself turning them off after someone else has left one on :)
Rydfree
Benny
Alabama
Which are useful how? Yes, they look cool, but do nothing.
Going to work every morning I ride through a low lying area with water on both sides of the road and this time of year it is completely fog . I use my fog lights as they help considerably being able to see the road since they are mounted down low . Your experience may not be the same as others .
BroncoActual
2018 Ford F-150 Raptor
A quick Google will show:
  1. In terms of power, given the brightness output, an LED will consume 5x - 6x less power than an incandescent:
    Ford Bronco Signature vs standard lights ? types-of-LED-lights-section-5
  2. In terms of lifespan, incandescents last anywhere from a few hundred hours to low thousand hours while LEDs last in the tens of thousands of hours
    Ford Bronco Signature vs standard lights ? Screenshot_2020-11-20 How Energy-Efficient Light Bulbs Compare with Traditional Incandescents
Efthreeoh
Hummer H3T
But seriously cut the power consumption on a 12V battery system in an automobile? Like it cuts 0.000000002 pound-foot of electrical drag on the alternator. LOL.
Your assuming the LEDs will be brighter; it depends on how Ford configures the LEDs. Plus most incandescent tail lights have redundant bulbs and the not all three light sources will burnout at the same time, statistically the high-mounted center brake light and the other side tail light will still function.
Rydfree
Benny
Alabama
It's hard to convince someone who thinks electrical is measured in Ft Lbs but yes , it is considerably less "Drag" on a vehicles electrical system . I saw these in person and they are also extremely well thought out and effective . The choice is yours however .
Used2jeep
Massachuvian
2007 Crown Vic P71
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
It sounds like he thinks the only benefit is the literal physical resistance added to the alternator and by extension on the engine?
I’m personally a huge fan of LEDs. Swapping out my hid driving lights for LEDs on my motorcycle meant my battery wasn’t draining at idle anymore, and I had the extra overhead for heated gear and cell phone charging.
Rydfree
Benny
Alabama
Yes they made considerable difference on my motorcycles . I also switched out the lights on my old '91 Ford Ranger that I drive to work everyday and it used to barely keep the battery charged with the stock lights . Now I can actually see and it is keeping a good charge . It has the original alternator on it at 327,000 miles so hopefully it will still not need replacement for awhile longer .
Headsong
you know, for lighting up the fog
But with idot requirement to have headlights on, it only helps me see the fog better! Lol
Appalachia_Ewok
J
Tennessee
'02 PT Cruiser, '62 DeVille, '96 XJ, '23 Bronco
Where these $1.00 incandescents at? it was like $50+ per bulb to get replacement incandescent bulbs in my car that were brighter than stock (to offset the clouding) but still not even as bright as LEDs.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
The rear incandescent bulbs.
Supersnay
Cincinnati
2017 Dodge Durango R/T
The yellow light accents on the standard lighting is definitely cool, but the main light is incandescent. It’s not shown lit up in those renderings, but I think it’ll look underwhelming. Car manufacturers have somewhat established a standard these days with led front lighting. Most people look for that in their cars. I personally prefer it.
This is not true, they both are LED lighting per specs.
Efthreeoh
Hummer H3T
Ah, power transmitted from the engine crank pulley to the alternator accessory drive pulley is measured in torque over time (pound-foot/sec), which = 1.3 watts per 1 pound-foot per sec.
Since none of us know the electrical circuit of the LED tail light vs. the incandescent version and each power consumption, it's merely am academic exercise at this point.
But I'll state that the minor effect of lowering the tail light power consumption (even less the brake light consumption) will have no perceivable effect on lowering fuel consumption.
85_Ranger4x4
Iowa
1985 Ford Ranger
No, it isn't LED bulbs it is a full sealed LED housing.
I know a guy with a '14 Mustang. Somebody backed into it and cracked the tail light. When it filled full of water and shorted out (thus when he noticed it) he called the dealer and a new housing was like $1200 (its a one piece sealed unit)
Yeah, I am a hard pass on that crap if I can help it. Regular bulbs last a great long while, like 10-15 years and hardly pull anything. LED replacement bulbs if you want to ride that bandwagon are pennies on the dollar for the cost of a replacement factory LED assembly (especially if they have sensors incorporated into it)
