Signature vs standard lights ?
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Ah, power transmitted from the engine crank pulley to the alternator accessory drive pulley is measured in torque over time (pound-foot/sec), which = 1.3 watts.
Since none of us know the electrical circuit of the LED tail light vs. the incandescent version and each power consumption, it's merely am academic exercise at this point.
But I'll state that the minor effect of lowering the tail light power consumption (even less the brake light consumption) will have no perceivable effect on lowering fuel consumption.
Ive never once upgraded to LED lighting for fuel consumption reasons... is anyone making that argument in this thread?
Efthreeoh
Hummer H3T
Fine, but why is a miniscule reduction in power consumption a reason to switch to LED as was stated as an advantage of LED.
I get the possibility of the LEDs never burning out and I'm not arguing that point, but my experience of over 40 driving years I've had to replace tail light bulbs maybe every 5 years and it take 10 minutes and the bulbs are very inexpensive.
Power consumption really isn't a good reason. If one thinks LED is cool, then that's a legit reason.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Power consumption as in the *amps* (not horse power) they draw is considerably less than incandescent.
On my dual-sport motorcycle for instance, the alternator was barely powerful enough to charge the battery while I was at idle... add to that some heated gear, my cell phone charger, and the ABS/assisted brakes, I was constantly running the risk of draining my battery even while riding at higher RPMs.
The solution in the past was to swap out for a "high output" alternator to cover the electrical draws... but now, by switching to LEDs, I was able to reduce the electrical load enough that the battery drain problem went away entirely even with the stock alternator.
This can play a major role, especially in a vehicle that is going to be modded, and potentially used away from civilization. If you're running a fridge, maybe some aux lighting, charging a go-pro, etc... utilizing LED lighting (vs incandescent) could mean the difference between having enough juice to crank your starter or being stranded when it comes time to leave.
Rydfree
Benny
Alabama
Let them build an off grid home with solar power and they will quickly realize the benefits of LED and far less power consumption :)
Lilj4425
Jacob
Greenville, SC
2021 Badlands Bronco
I never have either. Switching to LED lighting to save on fuel is almost like adding blinker fluid. lol.
Hoofnmouth
mark
N ca
ford focus st
If i were to install a fridgeor other high draw item id put in dual batteries
Efthreeoh
Hummer H3T
Good Lord, come on man, the Bronco will probably have a 2,000 watt alternator at least, it's not a motorcycle. Charge a go-pro, the battery could charge a go-pro and not even notice. Now we are just arguing for arguing sakes.
I made a valid point. LED power consumption is not a legit reason to go with the LED tails. LED Cool factor, the "B" design factor, all good reasons.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Ford Bronco Signature vs standard lights ? 1605892673260
85_Ranger4x4
Iowa
1985 Ford Ranger
Stuff like that and lawmowers are different. I have LED in my riding mower for this reason (to avoid the electric clutch slipping if alternator can't keep up)
In the land of 100-200+A alternators... 4A from two 3157 tail light bulbs is nothing though.
And if the truck isn't running and you are charging your gopro, running a fridge or in my case running a slide in camper... the tail lights are not on anyway.
Judge Rufus
Wheeler
Colorado foothills
Infiniti QX80, GMC Sierra, Mercedes SLK32 AMG,
Lucky, I've never had to do that. My mechanic does it for me every time I get an oil change.
Drex
Jake
standard looks 100 times better than the Signature. More fitting with the throwback design cues.
Headsong
Not the tails. And we're distinguishing signatures.
Efthreeoh
Hummer H3T
Where these $1.00 incandescents at? it was like $50+ per bulb to get replacement incandescent bulbs in my car that were brighter than stock (to offset the clouding) but still not even as bright as LEDs.
Okay, so maybe stock wattage incans are $3.50 each. Last time I replaced some in my 325I, 21-watt brakelight bulbs were under $8 a pack for two IIRC.
