Side step recommendation?
Colby
Philadelphia
I just added the Sasquatch wheels/tires. My wife is struggling a bit to climb in. Andy one have a recommendation for a side step/rock rail doodad that will make her life easier?
RagnarKon
Ford Bronco, Escape, Focus
MNBigfoot
MN
Take-off OEM, I got mine for $150, takes 15 minutes to install.
Anvilair1973
Tampa Florida
2024 Outer Banks - 2026 Badlands 2 door (wife's) and 1994 Mustang GT
I went with these for my 2 door and the 4 door version is even better looking. Same reason as you the wife insisted! Easy on the wallet too! RYNOSKIN Running Boards Fits 2021-2023 Ford Bronco 2 Door Heavy Duty Off Road Side Steps SUV Steel Nerf Bars Step Rails Heavy Texture Black https://a.co/d/9abDi6x
Clemmy
Mustang MachE
Ford Bronco Side step recommendation? A5FD7F0E-DE25-464D-A10C-A575677ABF81
Dominator Extreme D1. About $600 with shipping. 2 hour install. Quicker if you have two people.
Bronco_Mo
St. Peters, Mo
2023 Outer Banks
amp power steps, love em, clean look, makes getting in soooo much easier
Ford Bronco Side step recommendation? Screenshot_20230403-082213_Gallery
Colby
Philadelphia
Let me clarify, sorry. I already have the stock one but want something that sits lower.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Some Gamer
Central Texas
Ford Bronco
I saw the Go Rhino D6 dominators in person and fell in love. I am currently trying to decide between the bolt on version that fits in the same spot as the factory rock rails, or the frame mounted version that requires drilling.
Hans
Hans
So Cal
Suburban
I got door straps two bolts above your shoulder. 20-30 bucks ebay .Helps 6'6" 250lb guy move around.
Bill K
Allen, TX
Ford Bronco Big Bend 2 Door
I went with these for my 2 door:
https://www.amazon.com/dp/B0B1VJMP7...pY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU&th=1
Decent quality and pretty easy install. Wanted something wide enough to prevent door dings. Also wanted something full length to help people get in the back seat of my 2 door, and let me get full access to the roof rack. Also wanted something a little solid as I've seen some of the horror pictures of rock dings kicked up to the lower parts of the doors and lower trim (also have mud flaps for this). Like them OK, but I'm tall enough that I don't need them so have to slide over them getting in and out. Otherwise, satisfied all of my desires.
MayhemMike
Mercury
IAG company boards. Connect to factory rock rails. Easy on and easy removal.
Ford Bronco Side step recommendation? 7011E943-5791-4AE3-9155-3BFB5AD84EBF
