Side step recommendation?
GiaMia
Gia
Ford Bronco
amp power steps, love em, clean look, makes getting in soooo much easier
Where did you get these? Agree, looks very clean. Can you share the link or model?
Mrjay804
Jay
Metro Detroit
23 Black Diamond SAS
NFab Nerf RS Bolt right in factory rock rail holes and very easy install. Very reasonably priced as well.
Ford Bronco Side step recommendation? IMG_0021
Bronco_Mo
St. Peters, Mo
2023 Outer Banks
helifino16
Ron
Mount Sinai, NY (Long Island)
Despite having tube steps, I have to occasionally carry one of these to help her get up into the truck:
Ford Bronco Side step recommendation? 1686575238468
Probably the cheapest option, that doesn't reduce the ground clearance at all.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
I swapped out my OEM running boards to DV8 side steps. Made of steel for actual rock sliders and they sit up higher and gained me 2” of clearance. BONUS they also cover the pinch welds.
Ford Bronco Side step recommendation? IMG_1954
Ford Bronco Side step recommendation? IMG_1955
jacknifetoaswan
JR
Charleston, SC
2016 Mustang GT/PP
I have the Havoc Trailcrawler steps. Sturdy, well built, attractive, and not too expensive. They took 15 minutes to install, and it was my 10 year old who threaded and ran the bolts in with the impact while I held the steps in place.
Ford Bronco Side step recommendation? PXL_20230511_203359444
JR
rguest3
Raymond
Florida and Virginia
F-350, F-450, 23 Bronco, 24 Raptor, (2) 77 Broncos
I find that most side steps (factory or aftermarket) are actually too high. They do help you get up, but you then have to really duck your head to actually get in. Both my wife and I have this issue. (5 8" and 6 0")
On my Badlands I took off the factory side rails with the AIG steps (2" lower V2) installed because they were too high. I replaced with AMP Power Steps. When deployed the steps are lower than before, and make it easier to actually get in the truck. When you shut the door the steps are tucked up nice and high and out of the way. Like most of us, I don't need a slider as I do not Rock Crawl.
I have the Rock Slide Engineering side steps on my 4-door for the same reasons. These do have added protection but at a higher cost.
